[Empoeirado]  F/A-18 Hornet - Italeri - 1/48
Arturius
Nome: Artur Vicente Geronazzo
Mensagem por Arturius »
Dando início a mais essa montagem! :clap:
Roteiro a ser seguido:
- Histórico;
- Apresentação do kit; e
- Montagem.
Vamos ao histórico desse novo, mas clássico da aviação moderna. Vou dividir em duas partes, uma um histórico geral do avião e outro com ênfase na história com a RAAF.
McDonnell Douglas F/A-18 Hornet
Historical Snapshot
F/A-18 Hornet Fighter
The McDonnell Douglas F/A-18 Hornet was designed for aircraft carrier duty and was the first tactical aircraft designed to carry out both air-to-air and air-to-ground missions. The U.S. Marines ordered it as an F-18 fighter and the Navy as an A-18 attack aircraft. It can switch roles easily and can also be adapted for photoreconnaissance and electronic countermeasure missions.
The F/A-18 Hornet was also the first aircraft to have carbon fiber wings and the first tactical jet fighter to use digital fly-by-wire flight controls. Variants included a two-seater, an improved fighter, a reconnaissance aircraft and a night-attack fighter.
Hornets entered active duty in January 1983. In 1986, Hornets on the USS Coral Sea flew their first combat missions. During the 1991 Persian Gulf War, while performing an air-to-ground mission, Hornets switched to fighter mode and destroyed two Iraqi MiG-21s in air-to-air combat, then switched back to attack mode and successfully completed their air-to-ground mission. During 2001, Hornets provided around-the-clock battlefield coverage in the Afghanistan Theater of operations.
The F/A-18E/F Super Hornet made its first flight in November 1995. The Super Hornet is a low-observable aircraft that performs multiple missions, including air superiority, day-and-night strike with precision-guided weapons, fighter escort, and close air support. It is operational in 10 U.S. Navy Carrier Air Wings (25 squadrons) and the Royal Australian Air Force.
The Super Hornet is produced in the single-seat E model and the two-seat F model. The F/A-18E/F is 25 percent larger than the original Hornet and has increased maneuverability, range, payload and more powerful engines. It entered operational service with the U.S. Navy in 1999, after Boeing had merged with McDonnell Douglas, won the Collier Trophy for that year and flew its first combat missions in 2002.
In April 2005, Boeing delivered the first Block II Super Hornet, an upgraded Super Hornet with the world’s first tactical multimode active electronically scanned array (AESA) radar.
In 2008, the EA-18G Growler joined the Navy’s aircraft fleet. A Super Hornet derivative, the EA-18G provides tactical jamming and electronic protection for U.S. and allied forces, delivering full-spectrum airborne electronic attack capability along with the targeting and self-defense capabilities of the Super Hornet.
On April 22, 2010 — Earth Day— an unmodified, Boeing-built F/A-18F Super Hornet took off from Naval Air Station Patuxent River, Md., powered by a sustainable biofuel blend of 50 percent camelina and 50 percent JP-5 aviation fuel. Boeing had worked with the Navy on laboratory testing of fuel properties and engineering evaluations of fuel system compatibility. Nicknamed Green Hornet, the F/A Super Hornet has won seven consecutive awards for environmental excellence from the U.S. Navy.
In August 2013, Boeing and Northrop Grumman began flight tests with a prototype of an Advanced Super Hornet aircraft with conformal fuel tanks, an enclosed weapons pod and signature enhancements.
Technical Specifications
- F/A-18 Hornet Fighter
First flight - Nov. 18, 1978
Wingspan - 37 feet 5 inches
Length - 56 feet
Height - 15 feet 3.5 inches
Takeoff weight - Fighter, 36,710 pounds; attack, 49,224 pounds
Speed - 1,360 mph plus
Ceiling - 50,000 feet
Power plant - Two 16,000-pound-thrust GE F404-GE-400 low-bypass turbofan engines
Accommodation - One crew (F/A-18A/C); two crew (F/A-18B/D)
Armament - One 20 mm M61A1 Vulcan six-barrel cannon with 570 rounds, plus up to 17,000 pounds ordnance, including bombs, rockets, missiles and drop tanks on nine external points
fonte: http://www.boeing.com/history/products/ ... ornet.page
ADILSON
Registrado em: 10 Jun 2012, 11:25
Nome: Adilson Denis Jankowski
Re: F/A-18 Hornet - Italeri - 1/48
Mensagem por ADILSON »
Opa de olho....
Arturius
Em português:
História
Seu desenvolvimento começou em meados dos anos 70, quando a USN solicitou uma aparelho de baixo custo e multifuncional capaz de operar em porta-aviões, substituto do ultrapassado A-4 SkyHawk. O F-18 nasceu a partir do YF-17 que perdeu a concorrência de avião de baixo custo operacional da USAF para o F-16 que saiu vitorioso. No entanto o F-16 não era robusto o suficiente para operar em condições marítimas e também de péssima operação a partir de porta-aviões, então o projeto do YF-17 foi retomado, aprimorado e desenvolvido, dando origem então a um dos melhores jatos navais de todos os tempos, o F/A-18 Hornet.
Características
Podendo levar uma enorme variedades de armas , o F-18 logo se tornou o principal vetor da US Navy enquanto os F-14 garantem a interceptação de longo alcance, o Hornet dispõe da versatilidade de interceptações de curto alcance, defesa, ataque marítimo-terrestre e reconhecimento. Sua excelente manobrabilidade conferiu ao F/A 18 a fama de um dos melhores caças de combates a curta distância (dogfight).
Seus principais armamentos são o míssil de médio alcance ar-ar AIM-120 AMRAAM do tipo lançar e esquecer (fire-forget), o míssil de curto alcance orientado por sensores térmicos AIM-9 Sidewinder, o míssil ar-terra AGM-65 Maverick usado principalmente contra veículos de solo blindados e seu preciso (posicionado logo acima do seu nariz) canhão vulcan de 20 mm.
Um F/A-18 Hornet aguarda a próxima missão de combate a bordo do USS John C. Stennis, durante a Operação Enduring Freedom.
Funções de um super-caça
Atualmente, para ser eleito um caça de superioridade aérea/tecnológica, não basta apenas ter grande manobrabilidade e outros dotes de combate a curta distância, mas sim ser um caça multi-tarefas, capaz de agir e dar suporte à grande gama de requerimentos que o ambiente imprevisível de um conflito traz.
Entre outras funções do Super-Hornet estão:
- Ataques diurnos/noturnos com armamentos de alta precisão
- Sistema de guerra eletrônica
- Escolta armada
- Suporte aéreo de curto alcance
- Opressão à defesa aérea inimiga
- Ataque Marítimo
- Reconhecimento
- Liderança do controle aéreo
- Avião de reabastecimento
- Controle aereo
Flexibilidade
A versatilidade do Super-Hornet se aplica também aos seus armamentos e carga útil:
- 11 cabides (estações de suporte para armamento/equipamento)
- Suporte para armamento inteligente, incluindo bombas de orientação à laser
- Pode carregar uma gama de armamentos, tanto ar-ar quanto ar-superfície
Potência e características de voo
O Super Hornet é equipado com dois motores GE F414-GE-400
- Motores com circunferência variável que diminuem a assinatura no radar e promovem maior controle de ar/pressão na turbina
- 9.080 kg de empuxo por motor
Equipamentos e tecnologia
O F/A-18 possui variáveis mais atuais com grande acréscimo tanto de performance como máquina quanto como computador, seus sistemas de mira incluem o avançado Joint-helmet mounted cueing system (JHMCS), um sistema de mira a partir do visor do piloto, onde é necessário apenas o posicionamento da cabeça do piloto na direção do alvo, para que as bombas inteligentes detectem e mirem no alvo. Radar com varredura eletrônica ativa, ou Active electronically scanned array (AESA) entre outros grandes, versáteis e compatíveis sistemas de controle e mira.
Operações
Os Hornet viram ação pela primeira vez ainda em 1986, em ataques ao solo e destruição de defesas aéreas na Líbia, em apoio aos aviões A-6E Intruder e A-7 Corsair II; Em 1991, durante a operação Tempestade no deserto, os Hornet embarcados e dos Marines em bases terrestres, realizaram grande número de missões de ataque e apoio aéreo aproximado. Em 17 de janeiro, um par de F/A-18C do USS Carl Vinson, com escolta de dois F-14D Tomcat, estavam indo atacar a base aérea de H-2 no Iraque ocidental, quando um grupo de F-15C da USAF, pediu apoio aos Tomcat para dar conta de 4 MiG-25PD, deixando os F/A-18 sozinhos. 5 minutos depois, um avião de alerta E-3 sentry alertou os Hornet de que 2 J-7 (versão chinesa do MiG-21 Fishbed), surgiram a apenas 10km. Imediatamente os Hornet mudaram o radar do modo ar-terra para ar-ar, e em rápida sucessão, abateram os J-7 com o uso do AIM-7E3 Sparrow e do AIM-9M sidewinder. depois voltaram ao modo ar-terra e completaram o ataque a H-2, que foi muito bem sucedido. Nesta mesma primeira madrugada, um F/A-18C foi abatido por um MiG-25PD, com o uso do míssil R-40. De início, a US Navy até confirmou o abate, mas logo depois desmentiu, dizendo que a aeronave foi abatida por defesas antiaéreas (verificou-se, mais tarde, que a bateria mais próxima ao local do abate estava cerca de 45km de distância).
mais informações: https://pt.wikipedia.org/wiki/McDonnell ... -18_Hornet
Achei este vídeo bem bacana, vale apena ver:
Gundam_Maister
Nome: Dalton Miura
Mensagem por Gundam_Maister »
Um abelhudo australiano, achei interessante essa de biocombustíveis
GT 00 - Viva a Liberdade - Montagem: MiG-29 "The Swifts" - 1:144 - Revell GT 02 - F4 Phantom - Montagem: F-4E Phantom II - Academy - 1/144 GT 02 - F4 Phantom - Montagem: F-4E Phantom II - Academy - 1/144 GT XX - Inacabados & Restauração - Montagem: U.S. Navy LST Landing Craft - Testors - 1:613 GT XX - Inacabados & Restauração - Montagem: Resgate no Paredão Noroeste - 1/35 GT XX - Inacabados & Restauração - Montagem: Porta aviões - Revell - 1/700 GT 05 - Modelos Famosos - Montagem: F117 A Stealth Fighter - Revell - 1/144 GT 06 - Militaria "Buzão" - Montagem: Monty's Caravan - Revell - 1:76 GT 07 - Amigo Secreto - Montagem: Panzer II Ausf B - Dragon 1/144 (2014) GT 07 - Amigo Secreto - Montagem: Panzer III Ausf. E - Dragon 1/144 (2014) GT 08 - Trucks Militares - Montagem: Pak 40 75mm Anti-tank Gun & Truck - Airfix - 1/76 GT 10 - Figuras - Montagem: North American Black Bear & Cubs - Atlantis - 1/12 GT 10 - Figuras - Montagem: Avanço Lento - Figura Genérica - 1/35 GT 10 - Figuras - Montagem: Destruidor - Impressão 3D - sem escala GT 10 - Figuras - Montagem: Estátua Feminina - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Estátua Leão (Musei Capitolini) - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Estátua Leão (Kerepesi Cemetery) - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Agnes - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Hulk - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: American Eagle - Lindberg - 1/6 GT 10 - Figuras - Montagem: The Batman (Busto) - 1/4 GT 11 - Maquinas Voadoras Russas - Montagem: Suchoj S-37 Berkut - Revell - 1/144 GT 13 - Pendurados no Pincel - Montagem: F4U-1A Corsair - Revell - 1/72 GT 14 - Artilharias - Montagem: 105mm Howitzer - Testors/Italeri - 1/35 GT 16 - Debaixo D'agua - Montagem: USS Balao SS-285 - Hobby Boss - 1/700 GT 17 - Ficção Científica - Montagem: Baby Groot - scratch building - 1/1 GT 20 - Guerra no Deserto - Montagem: US 1/4 ton 4x4 M38A1C - Skybow - 1/35 GT 26 - Carros de Fórmula - Montagem: Lotus 79 - Nitto - 1/28 GT 27 - Aviação Civil - Montagem: Boeing 737-200 British Airways - Revell - 1/200 GT 29 - Bombardeiros - Montagem: Horten Go 229 - Revell 1/72 GT 29 - Bombardeiros - Montagem: B-25G Mitchell - Academy - 1/144 GT 32 - Tornado - Montagem: Tornado ECR TigerMeet - Revell - 1/144 GT 36 - Marines - Montagem: F/A-18C Hornet - Revell - 1/144 GT 37 - USAF - Montagem: F-15 Eagle - Academy - 1/144 GT 38 - Luftwaffe - Montagem: F-104 G Starfighter - Revell - 1/144 GT 39 - Protótipos - Montagem: Salt Flat Racers Turbo Go - Testors - 1/32 GT 39 - Protótipos - Montagem: SpaceShipTwo & WhiteKnightTwo - Revell - 1/144 GT 42 - Carros Americanos - Montagem: Sting Ray III - Revell - 1/25 GT 42 - Carros Americanos - Montagem: Chevy Corvette Coupe 2012 - AMT - 1/25 GT 43 - Navio a Vela - Montagem: Optimist Sailboat - Scratchbuilding - 1/25 GT 44 - STAR WARS 2015 - Montagem: R2-D2 - Metal Earth - 1/12 GT 44 - STAR WARS 2015 - Montagem: X-Wing - sem escala - Brinde Genérico GT 44 - STAR WARS 2015 - Montagem: Jedi Starfighter - Bandai - sem escala GT 44 - STAR WARS 2015 - Montagem: Star Wars First Order TIE Fighter Set - Bandai - sem escala GT 45 - Blindados na WWII - Montagem: White Half-track M3A1 & 1 Ton trailer - Airfix - 1/76 GT 46 - Guerra ao Terror - Montagem: EA-6B Prowler - Hasegawa - 1/72 GT 47 - Vietnam War - Montagem: Mig-21 Fishbed - Academy - 1/72 GT 48 - Carros Europeus - Montagem: Ferrari 360 Modena Spyder - Revell - 1/24 GT 49 - Pinturas e Camuflagens 'What if?' - Montagem: Mistel 5 - He162-A2 w/Arado E377-a - Dragon - 1/72 GT 51 - Primeira Guerra Mundial - Montagem: Nieuport N.28 C-1 - Revell - 1/72 GT 50 - The Fifties - Montagem: Fiat G.91R - Airfix - 1/72 GT 52 - Tudo o que sua imaginação permitir - Montagem: Sabriali Interceptor Mk I - Scratch - 1:72 GT 52 - Tudo o que sua imaginação permitir - Montagem: Ferrari 360 Modena Spyder (Autobot) - Revell - 1/24 GT 52 - Tudo o que sua imaginação permitir - Montagem: Mjölnir - Papercraft e Scratchbuilding - s/ escala GT 52 - Tudo o que sua imaginação permitir - Montagem: Drone - Scratchbuilding - 1/1 GT 52 - Tudo o que sua imaginação permitir - Montagem: Lightsaber Mestre Jedi Niellos - scratchbuilding - 1/4 GT 52 - Tudo o que sua imaginação permitir - Montagem: Lightsaber Mestre Jedi Sim-1 - scratchbuilding - 1/4 GT 52 - Tudo o que sua imaginação permitir - Montagem: Halo Commander Sarah Palmer - Bandai - Sem Escala GT 52 - Tudo o que sua imaginação permitir - Montagem: Sv-262Hs Draken III - Bandai - 1/144 GT 52 - Tudo o que sua imaginação permitir - Montagem: VF-31J Siegfried - Bandai - 1/144 GT 52 - Tudo o que sua imaginação permitir - Montagem: Grogu - Impressão 3D - Sem Escala GT 52 - Tudo o que sua imaginação permitir - Montagem: Iron Man Helmet - Impressão 3D - Sem Escala GT 52 - Tudo o que sua imaginação permitir - Montagem: SVD Rifle (Dragunov) - Platz - 1/12 GT 52 - Tudo o que sua imaginação permitir - Montagem: Howa Type 89 Rifle - Platz - 1/12 GT 52 - Tudo o que sua imaginação permitir - Montagem: M4A1 Rifle - Platz - 1/12 GT 53 - Pacific - Montagem: F4U-1 - Academy - 1/72 GT 54 - RAAF - Royal Australian Air Force - Montagem: BAE Hawk Series Mk. 100 - Italeri - 1/72 GT 55 - Harrier - Montagem: AV-8B Harrier II Plus - Revell - 1/144 GT 58 - Aces High - Montagem: Yak 1 (Lydia Litvyak) - ZTS - 1/72 GT 59 - SAR - Search and Rescue - Montagem: A-109 K2 Rega - Revell - 1/72 GT 59 - SAR - Search and Rescue - Montagem: Resgate no Paredão Noroeste - Diorama - 1/35 GT 59 - SAR - Search and Rescue - Montagem: Brincadeira ou Diversão - Diorama - 1/35 GT 59 - SAR - Search and Rescue - Montagem: Us-2 - Platz - 1/300 GT 59 - SAR - Search and Rescue - Montagem: Us-1/1a - Platz - 1/300 GT 59 - SAR - Search and Rescue - Montagem: Silverado CK 99 - Revell - 1/25 GT 60 - GT Ferrari - Montagem: Ferrari 512 S - Union - 1/24 GT 63 - Porta Aviões - Montagem: Shinano - Revell - 1/1200 GT 65 - F-14 Tomcat - Montagem: F-14 - Academy - 1/144 GT 67 - Grandes Modelos - Montagem: Samurai Sword - Doyusha - 1/3 GT 91 - Cenas e Impressões - Montagem: Em Busca de Sombra e Água Fresca -  Sem escala GT 91 - Cenas e Impressões - Montagem: O Homem Que Puxava o Gatilho - 1/35 GT 69 - Piores Goiabas Possíveis - Montagem: Supermarine Spitfire Mk XVI E - Heller - 1/72 GT 71 - Carros alemães - Montagem: VW Buggy - Revell - 1/32 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: M998 Desert Patrol - Italeri - 1/35 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: Daimler Dingo Scout Car - Revell - 1/76 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: Sd.Kfz.234/2 "Puma" - Roden - 1/72 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: Autoblinda AB 43 - Italeri - 1/72 GT 73 - F-16 Viper - Montagem: F-16 Fighting Falcon - Academy - 1/144 GT 74 - Duas Rodas - Montagem: Vespa Futurista P.Mk1 - Scratchbuilding - S/escala GT 75 - Embarcações - Montagem: JMSDF Harushio Class - Hobby Boss - 1/700 GT 75 - Embarcações - Montagem: Jangada - "Gravetobuilding" - Sem escala GT 75 - Embarcações - Montagem: Ship in The Bottle (Goleta) - Madeira Balsa - Sem Escala GT 75 - Embarcações - Montagem: Arca de Noé - Madeira Balsa - 1/500 GT 75 - Embarcações - Montagem: USS Balao SS-285 - Hobby Boss - 1/700 GT 75 - Embarcações - Montagem: Longboard - scratch building - S/escala GT 75 - Embarcações - Montagem: PLA Navy Type 039A - Hobby Boss - 1/700 GT 76 - Carros Orientais - Montagem: Lexus Zent Cerumo – Bandai – 1/43 GT 76 - Carros Orientais - Montagem: Mobil 1 SC - Bandai - 1/43 GT 77 - F-15 Eagle - Montagem: F-15 Eagle - Academy - 1/144 GT 78 - Corvette - Montagem: Chevy Corvette Coupe 2012 - AMT - 1/25 GT 79 - Aeronaves torpedeiras - Montagem: Aichi M6A1-K Nanzan (Seiran Kai) - Tamiya - 1/72 GT 80 - Forças Aéreas Desconhecidas - Montagem: Aero L-29 Delfin - Egito - Mark I Models - 1/144 GT 80 - Forças Aéreas Desconhecidas - Montagem: Mig-21 - Czech Air Force - Eduard - 1/144 GT 81 - Aeronaves de treinamento - Montagem: Zlín Z-42M - HobbyBoss - 1/72 GT 81 - Aeronaves de treinamento - Montagem: Folland Gnat T.1 - Airfix - 1/72 GT 82 - Transportes e Serviços - Montagem: Bedford QLT - Airfix - 1:76 GT 82 - Transportes e Serviços - Montagem: Bedford QLD - Airfix - 1:76 GT 82 - Transportes e Serviços - Montagem: Bike Tuk Tuk - Scratchbuilding - 1/76 GT 83 - Art Attack - Acrilex Challenge - Montagem: F-15 Eagle Strike - Revell - 1/144 GT 84 - Aeronaves do Bureau Mikoyan-Gurevich (MiG) - Montagem: Mig-15 - Eduard - 1/72 GT 85 - Guerra das Falklands/Malvinas - Montagem: LWB Landrover and Trailer - Airfix - 1/76 GT 87 - Força Aérea Italiana - Montagem: Macchi MC.200 - Sweet - 1/144 (373ª Esquadrilha; 153 grupo 1941) GT 90 - Blindados sobre lagartas - Montagem: Pz. IV Ausf.F2 - Dragon - 1/144 GT 90 - Blindados sobre lagartas - Montagem: Hornisse - Dragon - 1/144 GT 92 - ThunderBolt (Guilherme Augusto Sorrenti) - Montagem: A-10 Thunderbolt II - Revell - 1/144 GT 94 - Plasti*Brasil 10 Anos - Montagem: Pz. IV Ausf.F2 + Hornisse - Dragon - 1/144 [Mini Diorama]
Chegando........
Echo1_
Registrado em: 07 Dez 2015, 20:35
Nome: Rodrigo Barros
Mensagem por Echo1_ »
Chegando pra acompanhar (y)
Rodrigo1977
Registrado em: 10 Fev 2015, 17:39
Nome: Rodrigo Alves Ferreira
Mensagem por Rodrigo1977 »
Cheguei...
Jeymison dos Anjos
Registrado em: 21 Ago 2013, 19:26
Nome: Jeymison dos Anjos
Mensagem por Jeymison dos Anjos »
Linda aeronave. Cheguei para acompanhar!
Arturius
ADILSON escreveu:Opa de olho....
Valeu irmão! Primeirão, nem deu tempo de terminar a primeira parte da introdução... :agitado:
Gundam_Maister escreveu:Um abelhudo australiano, achei interessante essa de biocombustíveis
Aprendi bastante também sobre o modelo, ainda fica mais específico com a outra parte. Continua... :twisted:
leaopersico escreveu:Chegando........
Valeu parceiro!
Echo1_ escreveu:Chegando pra acompanhar (y)
Seja bem vindo!
Rodrigo1977 escreveu:Cheguei...
Ainda está na primeira fila, irmão... :mrgreen:
Jeymison dos Anjos escreveu:Linda aeronave. Cheguei para acompanhar!
Realmente dos "Modernos" os Hornets e Super Hornets são lindos, mas depois com os F-22 e F-35, credo... :thumbdown:
Abraços e obrigado a todos por acompanharem. :saudacao:
Gylber Soares
Nome: Gylber Cavalcanti
Agradeceu: 285 vezes
Curtiram: 127 vezes
Mensagem por Gylber Soares »
Não vais me esperar, é? Ufa! Cheguei à tempo!
Voltar para “GT 54 - RAAF - Royal Australian Air Force”
