[Concluído]  M3 Lee/Grant Medium Tank - Airfix - 1:76
Eduardo_Correa
Nome: Eduardo Correa
Mensagem por Eduardo_Correa »
Olá a todos, sejam bem vindos. Abrindo o que será minha terceira montagem Militaria, a ser feito em paralelo com o Tiger I. Como o Tiger, este kit ainda depende da boa vontade dos Correios para ser iniciado. O kit permite a montagem de ambas as versões do tanque Lee, versão Norte Americana e a Grant, versão Britânica. A diferença entre as duas versões é basicamente a torre, que é um pouco maior no Lee. Ainda não decidi qual versão será montada...
Artbox
O tanque, cuja apresentação tomo a liberdade de retirar da Wikipedia
The M3 Lee, officially Medium Tank, M3, was an American medium tank used during World War II. In Britain, the tank was called by two names based on the turret configuration and crew size. Tanks employing US pattern turrets were called the "Lee", named after Confederate general Robert E. Lee. Variants using British pattern turrets were known as "Grant", named after Union general Ulysses S. Grant.
Design commenced in July 1940, and the first M3s were operational in late 1941.[2] The U.S. Army needed a medium tank armed with a 75mm gun and, coupled with the United Kingdom's immediate demand for 3,650 medium tanks,[3] the Lee began production by late 1940. The design was a compromise meant to produce a tank as soon as possible. The M3 had considerable firepower and good armor, but had serious drawbacks in its general design and shape, including a high silhouette, an archaic sponson mounting of the main gun preventing the tank from taking a hull-down position, riveted construction, and poor off-road performance. They were extensively used in northern Africa.
Its overall performance was not satisfactory and the tank was withdrawn from combat in most theaters as soon as the M4 Sherman tank became available in larger numbers. In spite of this, it was considered by Hans von Luck (an Oberst (Colonel) in the Wehrmacht Heer and the author of Panzer Commander) to be superior to the best German tank at the time of its introduction, the Panzer IV (at least until the F1 variant).[4]
Despite being replaced elsewhere, the British continued to use M3s in combat against the Japanese in southeast Asia until 1945.
Development[edit]
In 1939, the U.S. Army possessed approximately 400 tanks, mostly M2 Light Tanks, with 18 of the to-be-discontinued M2 Medium Tanks as the only ones considered "modern".[6] The U.S. funded tank development poorly during the interwar years, and had little experience in design as well as poor doctrine to guide design efforts.
The M2 Medium Tank was typical of armored fighting vehicles (AFVs) many nations produced in 1939. When the U.S. entered the war, the M2 design was already obsolete with a 37 mm gun, an impractical number of secondary machine guns, a very high silhouette, and 32 mm frontal armor. The Panzer III and Panzer IV's success in the French campaign led the U.S. Army to immediately order a new medium tank armed with a 75 mm gun in a turret as a response. This would be the M4 Sherman. Until the Sherman reached production, an interim design with a 75 mm gun was urgently needed.
The M3 was the solution. The design was unusual because the main weapon – a larger caliber, medium-velocity 75 mm gun – was in an offset sponson mounted in the hull with limited traverse. The sponson mount was necessary because, at the time, American tank plants did not have the design experience necessary to make a gun turret capable of holding a 75 mm weapon. A small turret with a lighter, high-velocity 37 mm gun sat on top of the tall hull. A small cupola on top of the turret held a machine gun. The use of two main guns was seen on the French Char B1 and the Mark I version of the British Churchill tank. In each case, two weapons were mounted to give the tanks adequate capability in firing both anti-personnel high explosive and canister ammunition and armor-piercing ammunition for anti-tank combat. The M3 differed slightly from this pattern having a main gun that could fire an armor-piercing projectile at a velocity high enough for effectively piercing armor, as well as deliver a high-explosive shell that was large enough to be effective. Using a hull mounted gun, the M3 design could be produced faster than a tank featuring a turreted gun. It was understood that the M3 design was flawed, but Britain[7] urgently needed tanks. A drawback of the sponson mount was that the M3 could not take a hull-down position and use its 75 mm gun at the same time.The M3 was tall and roomy: the power transmission ran through the crew compartment under the turret basket to the gearbox driving the front sprockets. Steering was by differential braking, with a turning circle of 37 ft (11 m). The vertical volute-sprung suspension (VVSS) units possessed a return roller mounted directly atop the main housing of each of the six suspension units (three per side), designed as self-contained and readily replaced modular units bolted to the hull sides. The turret was power-traversed by an electro-hydraulic system in the form of an electric motor providing the pressure for the hydraulic motor. This fully rotated the turret in 15 seconds. Control was from a spade grip on the gun. The same motor provided pressure for the gun stabilizing system.
The 75 mm gun was operated by a gunner and a loader; sighting the gun used an M1 periscope – with an integral telescope – on the top of the sponson. The periscope rotated with the gun. The sight was marked from zero to 3,000 yd (2,700 m) with vertical markings to aid deflection shooting at a moving target. The gunner laid the gun on target through geared handwheels for traverse and elevation. The shorter barreled 75 mm M2 cannon sometimes featured a counterweight at end of the barrel to balance the gun for operation with the gyrostabilizer until the longer 75 mm M3 variant was brought into use.[8]
The 37 mm gun was aimed through the M2 periscope, mounted in the mantlet to the side of the gun. It also sighted the coaxial machine gun. Two range scales were provided: 0–1,500 yd (1,400 m) for the 37 mm and 0–1,000 yd (910 m) for the machine gun. The 37 mm gun also featured a counterweight – a long rod under the barrel – though it was ill maintained by crews who knew little about its use.
There were also two .30-06 Browning M1919A4 machine guns mounted in the hull, fixed in traverse but adjustable in elevation, which were controlled by the driver. These were, due to coordination issues, removed, though they would be seen on early Sherman tanks.[9]
Though not at war, the U.S. was willing to produce, sell and ship armored vehicles to Britain. The British had requested that their Matilda II infantry tank and Crusader cruiser tank designs be made by American factories, but this request was refused. With much of their equipment left on the beaches near Dunkirk, the equipment needs of the British were acute. Though not entirely satisfied with the design, they ordered the M3 in large numbers. British experts had viewed the mock-up in 1940 and identified features that they considered flaws – the high profile, the hull mounted main gun, the lack of a radio in the turret (though the tank did have a radio down in the hull), the riveted armor plating (whose rivets tended to pop off inside the interior in a deadly ricochet when the tank was hit by a non-penetrating round), the smooth track design, insufficient armor plating and lack of splash-proofing of the joints.[10] The British desired modifications for the tank they were purchasing. A bustle was to be made at the back of the turret to house the Wireless Set No. 19. The tank was to be given thicker armor plate for the turret than the original U.S. design, and the machine gun cupola was to be replaced with a simple hatch. Extended space within the turret of the new M3 also allowed the use of a smoke bomb launcher, although the addition of the radio would take the space for storage of fifty 37 mm rounds, reducing the ammunition capacity to 128 rounds. Several of these new "Grant" tanks would also be equipped with sand shields for action in North Africa, though they often fell off.[9][11] With these modifications accepted, the British ordered 1,250 M3s. The order was subsequently increased with the expectation that when the M4 Sherman was available, it could replace part of the order. Contracts were arranged with three U.S. companies. The total cost of the order was approximately US$240 million, the sum of all British funds in the US; it took the US Lend-Lease act to solve the financial shortfall.
The prototype was completed in March 1941 and production models followed, with the first British-specification tanks produced in July. Both U.S. and British tanks had thicker armor than first planned.[12] The British design required one fewer crew member than the US version due to the radio in the turret. The U.S. eventually eliminated the full-time radio operator, assigning the task to the driver. After extensive losses in Africa and Greece, the British realized that to meet their needs for tanks, both the Lee and the Grant types would need to be accepted.
The U.S. military used the "M" (Model) letter to designate nearly all of their equipment. When the British Army received their new M3 medium tanks from the US, confusion immediately set in[13] between the different M3 medium tank and M3 light tank. The British Army began naming their American tanks after American military figures, although the U.S. Army never used those terms until after the war.[14] M3 tanks with the cast turret and radio setup received the name "General Grant", while the original M3s were called "General Lee", or more usually just "Grant" and "Lee".
The chassis and running gear of the M3 design was adapted by the Canadians for their Ram tank. The hull of the M3 was also used for self-propelled artillery as with the original design of the M7 Priest, of which nearly 3,500 were built, and recovery vehicles.
Operational history[edit]
Of the 6,258 M3 variants manufactured in the United States, 2,855 (45%) were officially handed over to the British government. The M3 Grant first saw action with the Royal Armoured Corps in North Africa, during May 1942. However, most of the M3s ordered by the UK quickly became surplus to the requirements of the British Army.
1,700 were transferred to the Australian Army, for home defence and training duties in Australia.[15]
The British Indian Army received 900 Grants
A further 22% (1,386) were exported directly from the US to the Soviet Union,[16] although only 976 of these reached Russian ports, due to German U-boat and air attacks on Allied convoys.
North African campaign[edit]
The M3 brought much-needed firepower to British forces in the North African desert campaign.
The American M3 medium tank's first action during the war was in 1942, during the North African Campaign.[17] British Lees and Grants were in action against Rommel's forces at the Battle of Gazala on 27 May that year. Their appearance was a surprise to the Germans, who were unprepared for the M3's 75 mm gun. They soon discovered the M3 could engage them beyond the effective range of their 5 cm Pak 38 anti-tank gun, and the 5 cm KwK 39 of the Panzer III, their main medium tank. The M3 was also vastly superior to the Fiat M13/40 and M14/41 tanks employed by the Italian troops, whose 47 mm gun was effective only at point blank range, while only the few Semoventi da 75/18 self-propelled guns were able to destroy it using HEAT rounds.[18] In addition to the M3's 75 mm gun outranging the Panzers, they were equipped with high explosive shells to take out infantry and other soft targets, which previous British tanks lacked; upon the introduction of the M3, Rommel noted:
Up to May of 1942, our tanks had in general been superior in quality to the corresponding British types. This was now no longer true, at least not to the same extent.
Despite the M3's advantages and surprise appearance during the Battle of Gazala, it could not win the battle for the British. In particular, the high-velocity 88 mm Flak gun, adapted as an anti-tank gun, proved deadly if British tanks attacked without artillery support.[19]
Grants and Lees served with British units in North Africa until the end of the campaign. Following Operation Torch (the invasion of French North Africa), the U.S. also fought in North Africa using the M3 Lee.
The US 1st Armored Division had been issued new M4 Shermans, but had to give up one regiment's worth to the British Army prior to the Second Battle of El Alamein. Consequently, a regiment of the division was still using the M3 Lee in North Africa.
The M3 was generally appreciated during the North African campaign for its mechanical reliability, good armor protection and heavy firepower.[ii] In all three aspects, the M3 was capable of engaging German tanks and towed anti-tank guns.
However the high silhouette and low, hull-mounted 75 mm were tactical drawbacks since they prevented fighting from a hull-down firing position. In addition, the use of riveted hull superstructure armor on the early versions led to spalling, where the impact of enemy shells caused the rivets to break off and become projectiles inside the tank. Later models were built with all-welded armor to eliminate this problem. These lessons had already been applied to the design and production of the M4.
The M3 was replaced in front-line roles by the M4 Sherman as soon as the M4 was available. However, several specialist vehicles based on the M3 were later employed in Europe, such as the M31 armored recovery vehicle and the Canal Defence Light.
Eastern Europe
From 1941, 1,386 M3 tanks were shipped to the Soviet Union, with 410 lost during shipping.[21] These were supplied through the Lend-Lease program in 1942–1943.
Like Commonwealth units, Soviet personnel tended to refer to the M3 as the "Grant", even though the examples shipped to Russia were technically "Lee" variants. The official Soviet designation was ?3 ??????? (?3?) or "M3 Medium", to distinguish the Lee/Grant from the US-built M3 Stuart, which was also acquired by the USSR and known officially there as the ?3 ?????? (?3?) or "M3 light".
With almost 1,500 T-34s being built per month, Soviet use of the M3 declined after mid-1943. The Soviets still used the Lee/Grant on secondary fronts, such as in the Arctic during the Red Army's Petsamo–Kirkenes Offensive in October 1944.
Pacific War[edit]
In the Pacific War, armoured warfare played a relatively minor role for the Allies, compared with that of naval,[22] air,[23] and infantry units.
In the Pacific Ocean Theater and Southwest Pacific Theater, the U.S. Army deployed none of its dedicated armored divisions and only a third of its 70 other, separate tank battalions.
A small number of M3 Lees saw action in the central Pacific Ocean Theater during 1943.
While the US Marine Corps deployed all six of its tank battalions,[24] none of these were equipped with the M3 Lee. (USMC tank battalions were equipped initially with M3 Stuarts, which were replaced by M4 Shermans in mid 1944.[25])
Some M3 Grants played an offensive role with the Indian Army, in the South-East Asian theatre.
The Australian Army also used Grants during World War II, mainly for home defence and training purposes.
Pacific Ocean Theater[edit]
The only combat use of the M3 Lee by the US Army against Japanese forces[26] occurred during the Gilbert and Marshall Islands campaign of 1943.
Following the better-known landing at Tarawa, the US 27th Infantry Division made an amphibious assault on Makin Island with armoured support from a platoon of M3A5 Lees equipped with deep-wadding kits belonging to the US Army's 193rd Tank Battalion.
Burma[edit]
After British Commonwealth forces in Europe and the Mediterranean began receiving M4 Shermans, about 900 British-ordered M3 Grants were shipped to the Indian Army. Some of these saw action in the Burma Campaign.[15]
They were used by the British Fourteenth Army[27] until the fall of Rangoon,[27] performing "admirably" in Burma in 1944–45, in its original role: supporting infantry.[27][28]
In the Burma Campaign, the M3's main task was infantry support. It played a pivotal role during the Battle of Imphal, during which the Imperial Japanese Army's 14th Tank Regiment (consisting of mostly captured British M3 Stuart light tanks and their own Type 95 Ha-Go light tanks) encountered M3 medium tanks for the first time and found itself outgunned and outmatched by the British armor.[29] Despite their worse-than-average off-road performance, the M3s performed well as they traversed the steep hillsides around Imphal. Officially declared obsolete in April 1944,[27] the Lee nevertheless saw action until the end of the war.
Australia[edit]
At the beginning of the war, Australian Army doctrine viewed tank units as minor offensive components within infantry divisions. It had no dedicated armoured branch and most of its very limited capabilities in tank warfare had been deployed to the North African Campaign (i.e. three divisional cavalry battalions). By early 1941, the effectiveness of large-scale German panzer attacks had been recognised, and a dedicated armoured mustering was formed. The Australian Armoured Corps initially included the cadres of three armoured divisions – all of which were equipped at least partly with M3 Grants made available from surplus British orders.
The 1st Australian Armoured Division was formed with a view towards complementing the three Australian infantry divisions then in North Africa. However, following the outbreak of hostilities with Japan,[30] the division was retained in Australia. During April–May 1942, the 1st Armoured Division's regiments were reported to be re-equipping with M3 Grants and were training, in a series of large exercises, in the area around Narrabri, New South Wales.[30]
The cadres of other two divisions, the 2nd and 3rd Armoured Divisions were both officially formed in 1942, as Militia (reserve/home defence) units. These divisions were also partly equipped with M3 Grants.[31]
In January 1943, the main body of the 1st Armoured Division was deployed to home defence duties between Perth and Geraldton, Western Australia, where it formed part of III Corps.[30]
By the middle of the war, the Australian Army had deemed the Grant to be unsuitable for combat duties overseas and M3 units were re-equipped with the Matilda II before being deployed to the New Guinea and Borneo Campaigns. Due to personnel shortages, all three divisions were officially disbanded during 1943 and downgraded to brigade- and battalion-level units.[31]
Post-war use in Australia[edit]
During the war, the Australian Army had converted some M3 Grants for special purposes, including a small number of bulldozer variants, beach armoured recovery vehicles and wader prototypes.
Following the end of the war, 14 of the Australian Grants were converted to a local self-propelled gun design, the Yeramba, becoming the only SPG ever deployed by the Australian Army. Fitted with a 25-pounder field gun, the Yerambas remained in service with the 22nd Field Regiment, Royal Australian Artillery, until the late 1950s.
Many M3s deemed surplus to Australian Army requirements were acquired by civilian buyers during the 1950s and 1960s for conversion to earthmoving equipment and/or tractors.
Conclusion
Overall, the M3 was able to cope with the battlefield of 1942. Its armor and firepower were the equal or superior to most of the threats it faced, especially in the Pacific. Long-range, high velocity guns were not yet common on German tanks in the African theater. However, the rapid pace of tank development meant that the M3 was very quickly outclassed. By mid-1942, with the introduction of the German Tiger I, the up-gunning of the Panzer IV to a long 75 mm gun, and the first appearance in 1943 of the Panther, along with the availability of large numbers of Shermans, the M3 was withdrawn from service in the European Theater.
Variants
British designations in parentheses
US variants[edit]
M3 (Lee I/Grant I)
Riveted hull, high profile turret, gasoline engine. 4,724 built.
M3A1 (Lee II)
Cast (rounded) upper hull. 300 built.
M3A2 (Lee III)
Welded (sharp edged) hull. Only 12 vehicles produced.
M3A3 (Lee IV/Lee V)
Twin GM 6-71 diesel variant of welded hull. Side doors welded shut or eliminated. 322 built.
M3A4 (Lee VI)
Stretched riveted hull, 1 x Chrysler A57 Multibank engine, made up of five 4.12 litre displacement, 6-cyl L-head car engines (block upwards) mated to a common crankshaft, displacement 21 litres, 470 hp (350 kW; 480 PS) at 2,700 rpm. Side doors eliminated. 109 built.
M3A5 (Grant II)
Twin GM 6-71 diesel variant of riveted hull M3. Although it had the original Lee turret, it was referred by the British as Grant II. 591 built.
M31 Tank Recovery Vehicle (Grant ARV I)
Based on M3 chassis, with dummy turret and dummy 75 gun. A 60,000 lb (27,000 kg) winch installed.
M31B1 Tank Recovery Vehicle
Based on M3A3.
M31B2 Tank Recovery Vehicle
Based on M3A5.
M33 Prime Mover
M31 TRV converted to the artillery tractor role, with turret and crane removed. 109 vehicles were converted in 1943-44.
105 mm Howitzer Motor Carriage M7 (Priest)
105 mm M1/M2 howitzer installed in open superstructure. A gunless version was used as an OP (observation post vehicle)
155 mm Gun Motor Carriage M12
Designed as the T6. A 155 mm howitzer on M3 chassis. 100 built in 1942-1943. M30 Cargo Carrier on same chassis to transport gun crew and ammunition.
British variants
Grant ARV
Guns removed and replaced with armored recovery vehicle equipment.
Grant Command
Fitted with map table and extra radio equipment and having guns removed or replaced with dummies.
Grant Scorpion III
75 mm (3.0 in) gun removed, and fitted with Scorpion III mine flail, few made in early 1943 for use in North Africa.
Grant Scorpion IV
Scorpion III with additional motor to increase Scorpion flail power.
Grant CDL
From "Canal Defence Light"; 37 mm (1.5 in) turret replaced by one with a powerful searchlight for disorientation enemy and a machine gun. 355 were also produced by the Americans, who designated it Shop Tractor T10 to camouflage its purpose.
Australian variants[edit]
M3 BARV
A single M3A5 was converted into a "Beach Armoured Recovery Vehicle".
Yeramba Self Propelled Gun.
Australian SP 25 pounder. 13 vehicles built in 1949 on M3A5 chassis in a conversion very similar to the Canadian Sexton.
Designs based on chassis[edit]
Medium Tank M4 Sherman
Tank Cruiser, Ram - see article for full list of variants
105 mm Self Propelled Gun, Priest
Kangaroo armoured personnel carrier
25pdr SP, tracked, Sexton Mark I - Sexton Mark II was on a Grizzly chassis
M12 Gun Motor Carriage
Operators
Australia
Brazil
Canada
India
New Zealand
Philippines[citation needed]
Romania 4 captured in the Crimea during operations in early 1944[32]
Soviet Union
United Kingdom
United States
Editado pela última vez por Eduardo_Correa em 15 Fev 2018, 13:12, em um total de 1 vez.
Curtiram: 222 vezes
Re: M3 Lee/Grant Medium Tank - Airfix - 1:76
Chegando para acompanhar.
cesar2b
Nome: Cesar Vieceli
Mensagem por cesar2b »
Opa vou estar de olho, acho muito interessante esse tanque, para mim e mais um mini bunker ambulante com arma para todos os lados!
Enviado de meu Moto G (5S) usando Tapatalk
GT 00 - Viva a Liberdade - Montagem: MiG-29 "The Swifts" - 1:144 - Revell GT 02 - F4 Phantom - Montagem: F-4E Phantom II - Academy - 1/144 GT 02 - F4 Phantom - Montagem: F-4E Phantom II - Academy - 1/144 GT XX - Inacabados & Restauração - Montagem: U.S. Navy LST Landing Craft - Testors - 1:613 GT XX - Inacabados & Restauração - Montagem: Resgate no Paredão Noroeste - 1/35 GT XX - Inacabados & Restauração - Montagem: Porta aviões - Revell - 1/700 GT 05 - Modelos Famosos - Montagem: F117 A Stealth Fighter - Revell - 1/144 GT 06 - Militaria "Buzão" - Montagem: Monty's Caravan - Revell - 1:76 GT 07 - Amigo Secreto - Montagem: Panzer II Ausf B - Dragon 1/144 (2014) GT 07 - Amigo Secreto - Montagem: Panzer III Ausf. E - Dragon 1/144 (2014) GT 08 - Trucks Militares - Montagem: Pak 40 75mm Anti-tank Gun & Truck - Airfix - 1/76 GT 10 - Figuras - Montagem: North American Black Bear & Cubs - Atlantis - 1/12 GT 10 - Figuras - Montagem: Avanço Lento - Figura Genérica - 1/35 GT 10 - Figuras - Montagem: Destruidor - Impressão 3D - sem escala GT 10 - Figuras - Montagem: Estátua Feminina - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Estátua Leão (Musei Capitolini) - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Estátua Leão (Kerepesi Cemetery) - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Agnes - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Hulk - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: American Eagle - Lindberg - 1/6 GT 10 - Figuras - Montagem: The Batman (Busto) - 1/4 GT 11 - Maquinas Voadoras Russas - Montagem: Suchoj S-37 Berkut - Revell - 1/144 GT 13 - Pendurados no Pincel - Montagem: F4U-1A Corsair - Revell - 1/72 GT 14 - Artilharias - Montagem: 105mm Howitzer - Testors/Italeri - 1/35 GT 16 - Debaixo D'agua - Montagem: USS Balao SS-285 - Hobby Boss - 1/700 GT 17 - Ficção Científica - Montagem: Baby Groot - scratch building - 1/1 GT 20 - Guerra no Deserto - Montagem: US 1/4 ton 4x4 M38A1C - Skybow - 1/35 GT 26 - Carros de Fórmula - Montagem: Lotus 79 - Nitto - 1/28 GT 27 - Aviação Civil - Montagem: Boeing 737-200 British Airways - Revell - 1/200 GT 29 - Bombardeiros - Montagem: Horten Go 229 - Revell 1/72 GT 29 - Bombardeiros - Montagem: B-25G Mitchell - Academy - 1/144 GT 32 - Tornado - Montagem: Tornado ECR TigerMeet - Revell - 1/144 GT 36 - Marines - Montagem: F/A-18C Hornet - Revell - 1/144 GT 37 - USAF - Montagem: F-15 Eagle - Academy - 1/144 GT 38 - Luftwaffe - Montagem: F-104 G Starfighter - Revell - 1/144 GT 39 - Protótipos - Montagem: Salt Flat Racers Turbo Go - Testors - 1/32 GT 39 - Protótipos - Montagem: SpaceShipTwo & WhiteKnightTwo - Revell - 1/144 GT 42 - Carros Americanos - Montagem: Sting Ray III - Revell - 1/25 GT 42 - Carros Americanos - Montagem: Chevy Corvette Coupe 2012 - AMT - 1/25 GT 43 - Navio a Vela - Montagem: Optimist Sailboat - Scratchbuilding - 1/25 GT 44 - STAR WARS 2015 - Montagem: R2-D2 - Metal Earth - 1/12 GT 44 - STAR WARS 2015 - Montagem: X-Wing - sem escala - Brinde Genérico GT 44 - STAR WARS 2015 - Montagem: Jedi Starfighter - Bandai - sem escala GT 44 - STAR WARS 2015 - Montagem: Star Wars First Order TIE Fighter Set - Bandai - sem escala GT 45 - Blindados na WWII - Montagem: White Half-track M3A1 & 1 Ton trailer - Airfix - 1/76 GT 46 - Guerra ao Terror - Montagem: EA-6B Prowler - Hasegawa - 1/72 GT 47 - Vietnam War - Montagem: Mig-21 Fishbed - Academy - 1/72 GT 48 - Carros Europeus - Montagem: Ferrari 360 Modena Spyder - Revell - 1/24 GT 49 - Pinturas e Camuflagens 'What if?' - Montagem: Mistel 5 - He162-A2 w/Arado E377-a - Dragon - 1/72 GT 51 - Primeira Guerra Mundial - Montagem: Nieuport N.28 C-1 - Revell - 1/72 GT 50 - The Fifties - Montagem: Fiat G.91R - Airfix - 1/72 GT 52 - Tudo o que sua imaginação permitir - Montagem: Sabriali Interceptor Mk I - Scratch - 1:72 GT 52 - Tudo o que sua imaginação permitir - Montagem: Ferrari 360 Modena Spyder (Autobot) - Revell - 1/24 GT 52 - Tudo o que sua imaginação permitir - Montagem: Mjölnir - Papercraft e Scratchbuilding - s/ escala GT 52 - Tudo o que sua imaginação permitir - Montagem: Drone - Scratchbuilding - 1/1 GT 52 - Tudo o que sua imaginação permitir - Montagem: Lightsaber Mestre Jedi Niellos - scratchbuilding - 1/4 GT 52 - Tudo o que sua imaginação permitir - Montagem: Lightsaber Mestre Jedi Sim-1 - scratchbuilding - 1/4 GT 52 - Tudo o que sua imaginação permitir - Montagem: Halo Commander Sarah Palmer - Bandai - Sem Escala GT 52 - Tudo o que sua imaginação permitir - Montagem: Sv-262Hs Draken III - Bandai - 1/144 GT 52 - Tudo o que sua imaginação permitir - Montagem: VF-31J Siegfried - Bandai - 1/144 GT 52 - Tudo o que sua imaginação permitir - Montagem: Grogu - Impressão 3D - Sem Escala GT 52 - Tudo o que sua imaginação permitir - Montagem: Iron Man Helmet - Impressão 3D - Sem Escala GT 52 - Tudo o que sua imaginação permitir - Montagem: SVD Rifle (Dragunov) - Platz - 1/12 GT 52 - Tudo o que sua imaginação permitir - Montagem: Howa Type 89 Rifle - Platz - 1/12 GT 52 - Tudo o que sua imaginação permitir - Montagem: M4A1 Rifle - Platz - 1/12 GT 53 - Pacific - Montagem: F4U-1 - Academy - 1/72 GT 54 - RAAF - Royal Australian Air Force - Montagem: BAE Hawk Series Mk. 100 - Italeri - 1/72 GT 55 - Harrier - Montagem: AV-8B Harrier II Plus - Revell - 1/144 GT 58 - Aces High - Montagem: Yak 1 (Lydia Litvyak) - ZTS - 1/72 GT 59 - SAR - Search and Rescue - Montagem: A-109 K2 Rega - Revell - 1/72 GT 59 - SAR - Search and Rescue - Montagem: Resgate no Paredão Noroeste - Diorama - 1/35 GT 59 - SAR - Search and Rescue - Montagem: Brincadeira ou Diversão - Diorama - 1/35 GT 59 - SAR - Search and Rescue - Montagem: Us-2 - Platz - 1/300 GT 59 - SAR - Search and Rescue - Montagem: Us-1/1a - Platz - 1/300 GT 59 - SAR - Search and Rescue - Montagem: Silverado CK 99 - Revell - 1/25 GT 60 - GT Ferrari - Montagem: Ferrari 512 S - Union - 1/24 GT 63 - Porta Aviões - Montagem: Shinano - Revell - 1/1200 GT 65 - F-14 Tomcat - Montagem: F-14 - Academy - 1/144 GT 67 - Grandes Modelos - Montagem: Samurai Sword - Doyusha - 1/3 GT 91 - Cenas e Impressões - Montagem: Em Busca de Sombra e Água Fresca -  Sem escala GT 91 - Cenas e Impressões - Montagem: O Homem Que Puxava o Gatilho - 1/35 GT 69 - Piores Goiabas Possíveis - Montagem: Supermarine Spitfire Mk XVI E - Heller - 1/72 GT 71 - Carros alemães - Montagem: VW Buggy - Revell - 1/32 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: M998 Desert Patrol - Italeri - 1/35 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: Daimler Dingo Scout Car - Revell - 1/76 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: Sd.Kfz.234/2 "Puma" - Roden - 1/72 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: Autoblinda AB 43 - Italeri - 1/72 GT 73 - F-16 Viper - Montagem: F-16 Fighting Falcon - Academy - 1/144 GT 74 - Duas Rodas - Montagem: Vespa Futurista P.Mk1 - Scratchbuilding - S/escala GT 75 - Embarcações - Montagem: JMSDF Harushio Class - Hobby Boss - 1/700 GT 75 - Embarcações - Montagem: Jangada - "Gravetobuilding" - Sem escala GT 75 - Embarcações - Montagem: Ship in The Bottle (Goleta) - Madeira Balsa - Sem Escala GT 75 - Embarcações - Montagem: Arca de Noé - Madeira Balsa - 1/500 GT 75 - Embarcações - Montagem: USS Balao SS-285 - Hobby Boss - 1/700 GT 75 - Embarcações - Montagem: Longboard - scratch building - S/escala GT 75 - Embarcações - Montagem: PLA Navy Type 039A - Hobby Boss - 1/700 GT 76 - Carros Orientais - Montagem: Lexus Zent Cerumo – Bandai – 1/43 GT 76 - Carros Orientais - Montagem: Mobil 1 SC - Bandai - 1/43 GT 77 - F-15 Eagle - Montagem: F-15 Eagle - Academy - 1/144 GT 78 - Corvette - Montagem: Chevy Corvette Coupe 2012 - AMT - 1/25 GT 79 - Aeronaves torpedeiras - Montagem: Aichi M6A1-K Nanzan (Seiran Kai) - Tamiya - 1/72 GT 80 - Forças Aéreas Desconhecidas - Montagem: Aero L-29 Delfin - Egito - Mark I Models - 1/144 GT 80 - Forças Aéreas Desconhecidas - Montagem: Mig-21 - Czech Air Force - Eduard - 1/144 GT 81 - Aeronaves de treinamento - Montagem: Zlín Z-42M - HobbyBoss - 1/72 GT 81 - Aeronaves de treinamento - Montagem: Folland Gnat T.1 - Airfix - 1/72 GT 82 - Transportes e Serviços - Montagem: Bedford QLT - Airfix - 1:76 GT 82 - Transportes e Serviços - Montagem: Bedford QLD - Airfix - 1:76 GT 82 - Transportes e Serviços - Montagem: Bike Tuk Tuk - Scratchbuilding - 1/76 GT 83 - Art Attack - Acrilex Challenge - Montagem: F-15 Eagle Strike - Revell - 1/144 GT 84 - Aeronaves do Bureau Mikoyan-Gurevich (MiG) - Montagem: Mig-15 - Eduard - 1/72 GT 85 - Guerra das Falklands/Malvinas - Montagem: LWB Landrover and Trailer - Airfix - 1/76 GT 87 - Força Aérea Italiana - Montagem: Macchi MC.200 - Sweet - 1/144 (373ª Esquadrilha; 153 grupo 1941) GT 90 - Blindados sobre lagartas - Montagem: Pz. IV Ausf.F2 - Dragon - 1/144 GT 90 - Blindados sobre lagartas - Montagem: Hornisse - Dragon - 1/144 GT 92 - ThunderBolt (Guilherme Augusto Sorrenti) - Montagem: A-10 Thunderbolt II - Revell - 1/144 GT 94 - Plasti*Brasil 10 Anos - Montagem: Pz. IV Ausf.F2 + Hornisse - Dragon - 1/144 [Mini Diorama]
Chegando pra acompanhar!
Eduardo_Correa
Rogerio Kocuka escreveu:Chegando para acompanhar.
leaopersico escreveu:Chegando pra acompanhar!
cesar2b escreveu:Opa vou estar de olho, acho muito interessante esse tanque, para mim e mais um mini bunker ambulante com arma para todos os lados!
Sejam todos bem vindos, é um prazer te-los à bordo.... Só tenham paciência até a chegada do kit....
Kozaky
Registrado em: 18 Out 2017, 13:56
Nome: Ruslan Segursky
Mensagem por Kozaky »
Acompanhando tb.
Enviado de meu SM-G570M usando Tapatalk
Eduardo_Correa
Bom, depois de um longo inverno, eis eu aqui de volta...
Além da demora na chegada do kit, logo em seguida fui eu quem não pude me dedicar as montagens...
Finalmente consegui um tempo para o Gen Lee!
Kit contém 64 peças injetadas em plástico cinza claro, bem comum aos kits Airfix.
Manual simples, que indica uma montagem rápida... são apenas 7 passos na montagem...
ImagemImagem
São duas as opções de montagem, versão inglesa (Grant) ou americana (Lee). Farei a versão americana.Imagem
E vamos a montagem...
A montagem é simples, mas a qualidade do kit deixa um pouco a desejar. Tem bastante rebarba e nem tudo se encaixa muito bem... com um tanto de lixa e bisturi, consegui um resultado meio sofrível
Conjunto montado...Imagem
Chassi já tomando forma...Imagem
Blindagens laterais... ImagemImagemImagemImagem
Torre no lugar... Imagem
Bom, a montagem está feita... coisa rápida de se fazer, não toma mais do que algumas horas...
Agora é se partir para o acabamento... próxima parada primer
Curtiram: 222 vezes
Que legal que você iniciou a montagem. Está progredindo rápido.
Manda :bala: :bala: :bala: :bala: :bala:
Dougvoador
Mensagem por Dougvoador »
O kit na está é pronto para a pintura. :clap: :clap: :clap: :clap:
Dom
Nome: José Jonanthan Silva
Mensagem por Dom »
já estou por aqui :clap:
:bala:
Colador de papel. :D
