Retirado do Manual:
A very brief history: Developed based on the Soviet Union T-64 at the Morozov Design Bureau in Kharkov, the T-80 was putted into service in 1976. In 1985, a modernized version, T-80U developed. Featuring a newly designed turret which equipped with the second generation “Kontakt 5“ explosive reactive armour and a Brod-M deep wading equipment. Arming with a 125mm 2A46-1 smooth bore gun which can fire the 9M119 Refleks (AT-11 Sniper) guided missile and the Long-Rod penetrator (HVAPFSDS) 3BM46.
With a top speed of 70km/hour, T-80U is one of the fastest tank in service today, gas turbine engine and it was Being the first tank ever fitted with a gas-turbine engine, the GTD-1250 produced 1,250 hp (919 kW). Its mobility also ensured by the planetary power transmission controlled with hydraulic servo-system. Running gear featuring torsion bar suspension with hydraulic telescopic double-acting shock absorbers, RMSh track and rubber-tyred road wheels.
The tanks are currently in service with the Russian Federation Ground Forces and also exported to China, Cyprus and South Korea.
O Kit:With a top speed of 70km/hour, T-80U is one of the fastest tank in service today, gas turbine engine and it was Being the first tank ever fitted with a gas-turbine engine, the GTD-1250 produced 1,250 hp (919 kW). Its mobility also ensured by the planetary power transmission controlled with hydraulic servo-system. Running gear featuring torsion bar suspension with hydraulic telescopic double-acting shock absorbers, RMSh track and rubber-tyred road wheels.
O Kit é baseado no Tanque Russo T-80, foi desenvolvido nos finais dos anos 70, como resposta ao desenvolvimento dos tanques M1 Abrams e Leopard 2.
Fonte: http://en.wikipedia.org/wiki/T-80
A Caixa:
Muito bem desenhada, com uma imagem muito bonita do T-80U.
Nota:
As Árvores / Sprues:
O Kit contém:
391 Peças em Plástico Cinza, dividos em 24 árvores / sprues
2 Lagartas de Material Flexível
1 Photeched, com 33 partes utilizáveis
1 Fio, simulando a corda de aço
1 Kit de Decais
1 Manual de Instruções
1 Manual de Pintura
Algumas Peças em Detalhes:
Nota:
O After-Market:
A qualidade do "Cabo de Aço" não é das melhores se parecendo muito com aquelas cordas utilizadas em varal.
Nota:
O Manual:
O Manual é muito bem acabado e bem explicativo.
O Guia de Pintura do Tanque:
Nota:
As Considerações Finais:
O Kit tem uma qualidade excepcional, não existem rebarbas aparentes nas árvores e é muito bem detalhado inclusive simulando a solda em diversos pontos do kit, os decais são simples e limpos, as cores seguem a codificação da Tamiya, é um Kit indipensavel para quem gosta de militaria e quer representar um modelo que esta sendo utilizado até hoje por alguns países.
Nota Final:
Agradecimentos:
Agradecemos a HobbyEasy, em especial ao Daniel Chiu, por nos fornecer este Kit para Review. Pode ser encontrado através do Link abaixo:
http://www.hobbyeasy.com/en/data/zupqnx ... eilzl.html
