Fora este pequeno detalhe, a pintura está excelente, como sempre o e o pre-shadding, além da conta...
LAU-127 Guided Missile Launcher
LAU-128 Guided Missile Launcher
LAU-129 Guided Missile Launcher
The LAU-127/128/129 family of missile launchers is used with the AMRAAM and AIM-9 air-to-air missiles. The AIM-120 AMRAAM, being almost 180 pounds lighter than the AIM-7 Sparrow, can be either rail launched from the LAU-128 or the LAU-106 A/A. The LAU-128/A rail launcher is the standard rail launcher used today on the F-15, and on the F-22 a pylon fitted with two LAU-128/A rail launchers is fitted to each of the outboard stations.
The LAU-127 is a rail launcher designed to enable the Navy F-14 and F/A-18 aircraft to carry and launch AMRAAM. It provides the electrical and mechanical interface between the missile and launch aircraft as well as the two-way data transfer between missile and cockpit controls and displays to support preflight orientation and control circuits to prepare and launch the missile. The launcher will also be capable of carrying and launching the AIM-9L/M SIDEWINDER missile.
The F-15/AIM-9X weapon system consists of F-15 carriage of the AIM-9X missile on a LAU-128 Air-to-Air (A/A) launcher from existing AIM-9 certified stations. The AIM-9X will be an upgrade to the AIM-9L/M, incorporating increased missile maneuverability and allowing a high off-boresight targeting capability. The LAU-128/A launcher is also the wingtip launch rail on the F-16. The AIM-120 AMRAAM, being almost 180lbs lighter than the AIM-7 Sparrow, , can be either rail launched from the LAU-128 or the LAU-106 A/A. The BOL Dispenser (produced by Celsius Tech Electronics of Sweden) is a Non-Developmental Item (NDI) high capacity chaff and non-pyrotechnic infrared dispenser for aircraft self-protection developed for installation inside a missile launcher rail. The BOL Countermeasures Dispenser is available for integration into the LAU-127/128/129 family of AMRAAM and AIM-9X missile launchers. A prototype integrated in a LAU-128 Missile Rail Launcher on a US Air Force F-15 is being tested under the US Foreign Comparative Test program.
[Concluído] F-16C - Academy - 1/48
- Tchibum
- Nome: Luiz Mergulhão
Re: F-16C - Academy - 1/48
Luiz Mergulhão
Luiz Mergulhão
- Hartmann
- Nome: Alexandre Fontoura
Finalmente concluído, pessoal!
Seguem as fotos...
Ao longo deste m6es, outras montagens serão concluídas, com meu retorno a Manaus.
Seguem as fotos...
- Tiago Reis
- Nome: Tiago Reis
- Curtiram: 13 vezes
Assim que eu gosto, armado até os dentesHartmann escreveu:
Ficou incrível Hartmann, parabéns!
- Claudio Drago
- Nome: Claudio Dalmau Drago
- Curtiram: 72 vezes
Rapaz... apareceste! Tudo bem por aí?
Bom saber que você retornou à bancada e com o pé direito.
Esse F-16 ficou lindo. Parabéns!
- Hartmann
Valeu, pessoal!
Só falta mudar o status para concluído!
Muito muito bom!
Excelente resultado e ótimo seu retorno as bancadas!
- Hartmann
Obrigado, Lenilson!leaopersico escreveu:Muito muito bom!
Aos poucos vou retornando. Até o final de semana outras montagens serão encerradas ou terão avanços!
