[Concluído]  Panzerkampfwagen V Panther II - Dragon - 1/35
kogyro
Nome: Paulo Henrique
Mensagem por kogyro »
Boa noite vou montar o carro em questão.
Trata-se um um projeto para construção do Panzerkampfwagen Panther II com algumas modificações, na torre e um possível canhão L/71 88mm.
Devido a produção em massa do panther, o mesmo não foi pra frente.
Um pequeno resumo(em inglês) do Panther II.
Os americanos tem um chassis de um panther II com torre de um outro panther.
Panther II
The early impetus for upgrading the Panther came from the concern of Hitler and others that it lacked sufficient armor. Hitler had already insisted on an increase in its armor once, early in its design process in 1942. Discussions involving Hitler in January 1943 called further increased armor; initially referred to as Panther 2 (it became the Panther II after April 1943). This upgrade increased the glacis plate to 100 mm (3.9 in), the side armor to 60 mm (2.4 in), and the top armor to 30 mm (1.2 in). Production of the Panther 2 was slated to begin in September 1943.
In a meeting on February 10, 1943, further design changes were proposed - including changes to the steering gears and final drives. Another meeting on February 17, 1943 focused on sharing and standardizing parts between the Tiger II tank and the Panther 2, such as the transmission, all-steel roadwheels, and running gear. Additional meetings in February began to outline the various components, including use of the 88 mm L/71 KwK 43 gun. In March 1943, MAN indicated that the first prototype would be completed by August 1943. A number of engines were under consideration, among them the new Maybach HL 234 fuel-injected engine (900 hp operated by an 8-speed hydraulic transmission).
Thus, plans to replace the original Panther design with the Panther II were already underway before the first Panther had even seen combat. But from May to June 1943, work on the Panther II ceased as the focus was shifted to expanding production of the original Panther tank. It is not clear if there was ever an official cancellation - this may have been because the Panther II upgrade pathway was originally started at Hitler's insistence. The direction that the design was headed would not have been consistent with Germany's need for a mass-produced tank, which was the goal of the Reich Ministry of Armament and War Production.
One Panther II chassis was completed and eventually captured by the U.S.; it is now on display at the Patton Museum in Fort Knox. An Ausf G turret is mounted on this chassis.
Em breve fotos.
Desde já agradeço a participação.
Editado pela última vez por kogyro em 29 Jun 2013, 20:59, em um total de 1 vez.
Seu Madruga
thiriboldi
Nome: Thiago Riboldi
Re: Panzerkampfwagen V Panther II - Dragon 1/35
Mensagem por thiriboldi »
Primeirão!
overdark999
Nome: Milton Soares
Mensagem por overdark999 »
segundo na primeira fila1!!!!!
Milton
kogyro
Obrigado por acompanharem.
Segue uma atualização, o kit é muiiito bom essa montagem foi iniciada após as 13 horas de hoje.
Segue.
Se tudo der certo, amanhã coloco as alças e as outras pequenas peças que faltam, vou limpar os rodeiros e destacar as lbl :raiva:
Seu Madruga
overdark999
Nome: Milton Soares
kogyro escreveu:Obrigado por acompanharem.
Segue.
Ta FICANDO MUITO BOA A MONTAGEM.
O encaixe foi perfeito ou teve muita lixa no meio do caminho?
E as grelhas do motor sao PE?
Milton
kogyro
Obrigado.
O problema maior foi o encaixe da parte de cima com a de baixo, tive que usar CA para colar e juntar as partes.
Do mais o kit monta bem.
Seu Madruga
Acompanhando e aprendendo aqui... :thumbup: :thumbup:
Quero ainda nesse ano montar militaria!
Roland
Nome: Vinicius Roland
Mensagem por Roland »
Tá vendo, André... tamo mudando de departamento?? Ou melhor adicionando, né?
Eu to entrando de sola na Aviação e vc querendo entrar na militaria. :thumbup:
Que show de kit meu amigo!!! Excelente trabalho!!
kogyro
hahaha o primeiro desafio chegou, algumas peças dos rodeios estão tortas :palavrao: :palavrao: , TODAS as partes da suspensão são maiores do que é pra ser.
Vamos ver o que dá.
Seu Madruga
Voltar para “GT 15 - Peito de Aco, poder de fogo”
