[Concluído]  Ti-67 Israel(tyran 5) - Trumpeter - 1/35
kogyro
Nome: Paulo Henrique
Mensagem por kogyro »
Buenas pessoal vou seguir a montagem desse kit, amanhã fotos.
Editado pela última vez por kogyro em 09 Mai 2013, 21:14, em um total de 1 vez.
Seu Madruga
NACHTJÄGER
Nome: Helerson Maciel
Re: Ti-67 Israel(tyran 5) - Trumpeter 1:35
Mensagem por NACHTJÄGER »
Vou acompanhar esta montagem!
Esse cara é o principal incentivador da minha ida para o lado negro da força (militaria 1/35) :rir_muito: :rolando: :aeee:
Aguardando estas fotos.
[]s!
kogyro
NACHTJÄGER escreveu::clap: :clap: :clap:
[]s!
Valeu Bruxo é nois.
Uma historinha sobre ele, até pq é díficil de achar algo com esse carro.
History of the Tiran in IDF service
The T54 was designed during the mid to late 1940s. First production models with an early pattern turret were started rolling off assembly lines in 1949. the new tank would incorperate the D-10 100mm gun originally intended for a SU anti tank vehicle similiar to the SU-85. This gun specifically and the T-54 in general would send the western allies scrambling for a comparible weapon during the early part of the 1950s culminating in the adoption of the British L68 105 mm rifled main gun as the NATO standard.
The T-54 would recieve numerous upgrades during the early 1950s. some of which included amin gun stabilization, night fighting equipment and a fume extractor at the end of the barrel. The T54 would be licenced produced in many warsaw pact countries as well as in China under the T-59 designation. The next step in the evolution was the advent of the T-55 series. Although very similiar to the T-54, The T55 had numerous improvements over the T-54 series. The most notable difference between the two was the deletion of the ventilator dome in front of the loader. There were also more important shanges in automotive ability as well as an eventual laser range finder.
The next step in soviet tank evolution was the T-62. although similar in general appearence to the earlier T-54/55 series, the T62 was a very different tank. The turret on the T-62 has a more balistic form and is a single peice casting. main armament is a 115 mm main gun. the engine deck also has minor changes as well from the T-55 series. The Hull of the T-62 is longer and wider than the t-55. Two quick ways to Identify a T62 from a T-55 is the location of the fume extractor on the barrel. on the T-62 it is about a third down from the point , on the T-55 it is literally at point of the barrel. the second way is the spacing of the road wheels. where the T55 has a space between the first and second road wheels the T-62 has a space between the third and fourtha as well as between fourth and fifth.
The IDF Tiran
The is the name given to this series of vehicle in the IDF. Although there is some debate as to its origin, It most likely comes from the primary cause of the Six Day war, which was the closing of the Straights of Tiran. For certain however the designation Ti-67 is a Janes or other printing house fantasy or a miscopy that became its nickname. The First Tirans came into IDF hands during the Six Day War. These were mostly late model T-54s as distiguished by the roof top ventilator although some T-55s were captured as well. While exact numbers are not known, enough were captured to arm at least 3 battalions during the 1973 Yom Kippur war. Following the Yom Kippur war even more t54/55s were captured as well as the latest T-62s. Again while exact numbers are not known, it wouldn't be far fetched to say enough vehicles were captured to equip a number of brigades.
Acccording to IDF designations there are three Tirans, Tiran4, 5, and 6. Four for theT-54, five for the T-55 and Six for the T-62. While there have numerous updates and modifications of the Tirans I have been unable to find any sub designations for them. or rather any IDF designationtions media ones abound. The IDF also made use of a number of support vehicle based on the T-55 chassis such as bridgelayers and engineer vehicles. To the best of my knowledge these retained their Identification numbers and few modifications other than radio equipment were made to the vehicles.
Like most other tools the IDF began an almost immediate improvement project to modify and upgrade the captured vehicles. Some vehicles are seen with early straight barrel 100mm guns and only two water cans added to the rear of theturret. By 1973 the 100mmm gun is repalced by the standard 105mm found on western tanks, now built under license in Israel. This was possibly the hardest modification as it entailed flipping the Breach so it could be loaded from the right side.extra antenna mounts were added . By 1973 only the rear stowage basket, the affore mentioned 105mm modification. 2 watercan holders were placed behind the loader,along with a small storage box. the vehicles seen were armed with one .30 cal. crew served weapon mounted sectraly on the turret top.
The hard lessons learned during the Yom kippur war brought about alot of doctrinal cnages in the IDF, as well as physical changes to it armour fleet. By the late 70s early 80s. The changes no seen in the Blast and Legendupdate sets were in place. By the end of the 80s the main battle tank version of the T55 series were withdrawn friom service. T54/55 series hulls however were modified into APCs using the latest modular armour technology. This gave mechnized infantry the same protection on the battlefield as any tank enhancing crew survivability.
Israel has had so much experience with Soviet armour they now sell upgrade packages to almost all the former Soviet client states. Isreali test beds have included blazer packages, Merkava style turret basket and Urdn style cupolas. While the T54/55/62 series is concidered obsolete in the european arena, they still soldier on in many third world countries. Israeli influence can clearly be seen in communist China's up graded armour fleet. The T54/55 definitely has made a place for itself in armour history, along with tanks like the Sherman, Centurion and Patton.
Algumas fotos do inicio da montagem.
o Gap é quase imperceptível.
Parte de cima
praticamente não se vê marcas de injeções XD
E um dry da coisa se formando.
Logo mais posto mais fotos.
obrigado.
Seu Madruga
adolfocaetanonetto
Nome: Adolfo Caetano Netto
Gostei da textura da torre! :thumbup: :thumbup: :thumbup:
Tenho um desse então vou acompanhar essa montagem com certeza!!
Acho bem legal quando os caras conseguem dar essa textura de ferro fundido nos blindados... Fica muito realístico depois de montado. :thumbup:
kogyro
Obrigado por acompanharem amigos, esse kit é bem goiabinha, baratinho mas goiaba esse molde dever ser bem antigo.
Seu Madruga
kogyro
Buenas pessoal, segue uma atualização.
Enquanto eu monto e com o frio que tava por esses dias, minha ajudante estava cuidando dos kit no estoque XD.
Essa parte não está pronta estou esperando secar.
Agora é correr atrás ta tinta certa.
Espero que gostem, críticas construtivas sempre bem vindas.
Seu Madruga
NACHTJÄGER
Tchê!
Tais descascando muito bem esta goiaba.
Tô gostando do resultado.
Até o momento, nada a sugestionar.
Estoquezinho bem diversificado hein?!
:pensando: :pensando: :pensando:
[]s!
cesar2b
Nome: Cesar Vieceli
Mensagem por cesar2b »
Opa kogyro ta ficando muito bacana meus parabens
vai adicionar acessórios nesse ai?
Voltar para “GT 15 - Peito de Aco, poder de fogo”
