[Concluído] Vulture Droid (Star Wars) - Eletric Products - 1/35
Moderadores: LRFOGA, Moderadores GT
- cesar2b
- Nome: Cesar Vieceli
Amigos como sei que muitos não tem problemas em ler em inglês vou postar aqui uma descrição do Vulture Droid(Droid Abutre em portugues)
The Variable Geometry Self-Propelled Battle Droid, Mark I (also known as the Vulture-class droid starfighter or simply as the Vulture droid) was a droid starfighter used by the Trade Federation.
DESCRIPTION
The effectiveness of droid starfighters has been debated in strategic circles for generations. While droid starfighters are capable of maneuvers that would crush even the sturdiest organic pilot, they lack the resourcefulness and cunning that living pilots bring into combat. To counter their shortcomings, vulture droids often attack en masse. Like the ground-based battle droid infantry, vulture droids were, for a time, controlled by a central command ship, but later generations were granted a limited degree of independence. When not in flight, the droid starfighter can transform into a walking mode allowing them to be used in surface patrols.
STATS
Appearances:Episode I/The Clone Wars/Episode III
Height:1.86 meters tall (flight configuration); 6.96 meters long (flight configuration); 6.87 meters tall (walking configuration)
Type:Droid starfighter
Weapon:Twin blaster cannons, two energy torpedo launchers, buzz droid missile launcher
Affiliation:Trade Federation, Separatist Alliance
Bom vamos ao Kit
Ele contem apenas 3 peças ,porem é bem detalhadas e a um preço muito bom (30 reais)
Seu maior defeito e a grande quantidades de rebarbas mas nada que uma boa lixada não ajude
Também irei trocar os canos das armas por um com furos
e consertar uns probleminhas
Sobre os esquemas de pintura a 3 (sendo 2 variaveis)
No inicio (pre-clone wars)se usava marrom e cinza ,sendo marrom a base e o cinza podendo variar
Com o inicio da clone wars a pintura foi padronizada ,para a base cinza claro,com listras cinza escuro,detalhes em azul e branco
Na segunda faze da clone wars o padrão voltou a ser aleatório,porem continuando com as mesmas cores de antes
A ideia e justamente recriar algum padrão aleatório da segunda fase da clone wars
E depois que terminar os projetos que estão na minha bancada mando bala nesse
DESCRIPTION
STATS
Bom vamos ao Kit
Editado pela última vez por Lessa em 13 Jan 2014, 07:45, em um total de 2 vezes.
Razão: TÃtulo ajustado.
- LRFOGA
- Nome: Luiz Renato Fogagnolo
Re: Vulture Droid (Star wars) /Eletric Products/ 1:20
Tenho um kit da AMT que vem 3 desses droids, é o mesmo kit?
- cesar2b
Luiz não o mesmo o da AMT vem 3 na escala 1/48 ja o meu e um na 1/20
mas o legal de vim 3 e que você pode fazer as 3 versões
- cesar2b
Tava dando uma olhada e parece que na verdade o ele e 1/35 não 1 20 vou ate falar pra Eletric
o aqui uma foto com um boneco 1/35 do lado
e aqui a o projeto original do droid que tava para ver o tamanho esse droid pequeno tem o tamanho de uma pessoa
- Sekiji
- Agradeceu: 31 vezes
- Curtiram: 28 vezes
Re: Vulture Droid (Star wars) /Eletric Products/ 1:35
Cesar, muito louco o kit! Não conhecia essa fase Clone Wars, sou fã da fase classica
- Kyosanin
- Nome: Tanderson Morales
- Agradeceu: 15 vezes
- Curtiram: 12 vezes
Muito legal César.. ansioso aqui pra ver como você vai fazer a camu..
- cesar2b
Opa esse sai alguma coisa ainda hoje ou amanha,como disse em outro topico,ja tenho a tinta mas esqueci de comprar o thinner
- cesar2b
Atualização
Primeira coisa a fazer foi remover o excesso de resina com uma micro-retificadeira
resolvi tirar as armas,pretendo fazer em scrath (mais ta dando um trabalho!!!
com uma pecinha da ponta cortada e com a resina removida fiz o molde
e copiei o bico,agora vou sair pra comprar um tupo do mesmo diâmetro que o antigo
depois passei pro corpo do droid(ja avia feito um wash pra te uma ideia dos detalhes,e tambem pintei um pouco dos olhos pois pretendo pintar agora e ja mascarar)
nota se que o antigo tinha as metralhadoras sem furos
então retirei e coloquei umas novas feitas com agulhas(ainda não tinha lixado o excesso de putty nessa foto)
depois aumentei as linhas de relevo em todo o kit
consertei alguns danos(haja putty e lixa!!!)
e tapei o buraco das assas
agora esta assim,esperando a pintura(sei que falta as armas ,mais vou fazer elas no pincel mesmo,porque quero estrear mu novo aerógrafo )
Amanha tem mais
Amanha tem mais
- cesar2b
Atualizando
Passei o primmer em algumas partes
Com mascara liquida cobri os olhos(esse negocio fede tanto que doí ate a alma )
E ai o momento pra estreia meu aerografo
resultado AMEI
Depois pintei com a cor base
mascarei
e pintei o cinza claro
resultado
depois fiz irregularidades nas linhas com o aerógrafo a mão livre
Obrigado por acompanharem
amanha tem mais
resultado AMEI
mascarei
resultado
amanha tem mais
- cesar2b
Pequena atualização
O único problema pra mim das acrílicas e que qualquer coisa elas saem
Decidi retirar as mascaras da parte de baixo do corpo do droid, já que não vai ter mais pintura para ver como fico,dai vi que estava assim
Detalhe,não mexi na peça e esse grande risco que ta ai foi por ter deixado em cima de um pincel
dai resolvi passa Brilho fácil pra selar tudo logo
depois já aproveitando o embalo colei as asas
mais tarde acho que termino a pintura
