[Concluído]  F6F-5 - HobbyBoss - 1/48
kogyro
Nome: Paulo Henrique
Mensagem por kogyro »
Pessoal como o meu Pe chegou, darei inicio nesse kit, a principio parece ser um bom kit.
Grumman F6F Hellcat
The Grumman F6F Hellcat was a carrier-based fighter aircraft initially conceived to replace the earlier F4F Wildcat in United States Navy (USN) service. Although the F6F resembled the Wildcat, it was a completely new design,[4] powered by a 2,000 hp Pratt & Whitney R-2800, the same powerplant used for both the Navy's earlier Chance Vought F4U Corsair and the Army Air Force's Republic P-47 Thunderbolt fighters. Some military observers tagged the Hellcat as the "Wildcat's big brother".[5]
The F6F was best known for its role as a rugged, well designed carrier fighter which was able, after its combat debut in early 1943, to counter the Mitsubishi A6M and help secure air superiority over the Pacific Theater. Such was the quality of the basic simple, straightforward design, the Hellcat was the least modified fighter of the war, with a total of 12,200 being built in just over two years.[6] Hellcats were credited with destroying 5,223 aircraft while in service with the U.S. Navy, U.S. Marine Corps and the Royal Navy's Fleet Air Arm[7][N 2] This was more than any other Allied naval aircraft, with its closest competitor on the Allied side being the USAAF's P-51 Mustang, which claimed some 4,950 enemy aircraft shot down and a further 4,131 destroyed on the ground during the war in the European Theatre.[citation needed][further explanation needed] Postwar, the Hellcat was phased out of front line service, but remained in service as late as 1954 as a night fighter.
F6F Hellcat
Grumman F6F-3 Hellcats in tricolor camouflage.[1][N 1]
Role Fighter aircraft
Manufacturer Grumman
First flight 26 June 1942
Introduction 1943
Retired 1960 Uruguayan Navy[2]
Primary users United States Navy
United States Marine Corps
Royal Navy
French Navy
Produced 1942–1945
Number built 12,275
Unit cost $35,000 in 1945[3]
Design and development
[edit]XF6F
The unpainted XF6F-1 prior to its first flight.
Grumman had been working on a successor to the F4F Wildcat since 1938 and the contract for the prototype XF6F-1 was signed on 30 June 1941. The aircraft was designed to use the Wright R-2600 Twin Cyclone two-row, 14-cylinder radial engine of 1,700 hp (1,268 kW) driving a three-bladed Curtiss Electric propeller.[9] Instead of the Wildcat's narrow-track, hand-cranked undercarriage retracting into the fuselage, the Hellcat had wide-set, hydraulically actuated undercarriage struts which rotated through 90° while retracting backward into the wings, much like that of the earlier Chance Vought F4U Corsair.[10] The wing was mounted lower on the fuselage and was able to be hydraulically or manually folded, with each panel outboard of the undercarriage bay folding backwards, parallel to the fuselage with the leading edges pointing down.[11]
Throughout early 1942 Roy Grumman, along with his chief designers Jake Swirbul and Bill Schwendler, worked closely with the U.S. Navy's Bureau of Aeronautics (abbreviated BuAer) and experienced F4F pilots,[12] to develop the new fighter in such a way that it could counter the Zero's strengths and help gain air command in the Pacific Theater of Operations.[13] On 22 April 1942, Lieutenant Commander Butch O'Hare toured the Grumman Aircraft company and spoke with Grumman engineers, analyzing the performance of the F4F Wildcat against the Mitsubishi A6M Zero in aerial combat.[14][N 3] BuAer's LT CDR A. M. Jackson [N 4] directed Grumman's designers to mount the cockpit higher in the fuselage.[17] In addition, the forward fuselage sloped down slightly to the engine cowling, affording the Hellcat's pilot good visibility.[18]
Based on combat accounts of encounters between the F4F Wildcat and A6M Zero, on 26 April 1942, BuAer directed Grumman to install the more powerful 18-cylinder Pratt & Whitney R-2800 Double Wasp radial engine in the second XF6F-1 prototype.[19] Grumman complied by redesigning and strengthening the F6F airframe to incorporate the 2,000 hp (1,500 kW) R-2800-10, driving a three-bladed Hamilton-Standard propeller. With this combination Grumman estimated the XF6F-3s performance would increase by 25% over that of the XF6F-1.[5] The Cyclone-powered XF6F-1 (02981) first flew on 26 June 1942, followed by the first Double Wasp-equipped aircraft, the XF6F-3 (02982), which first flew on 30 July 1942. The first production F6F-3, powered by an R-2800-10, flew on 3 October 1942, with the type reaching operational readiness with VF-9 on USS Essex in February 1943.[20] [N 5]
[edit]Further development
An early F6F-3 in Blue-Gray over Light Gull-Gray.
The F6F series were designed to take damage and get the pilot safely back to base. A bullet-resistant windshield and a total of 212 lb (96 kg) of cockpit armor was fitted, along with armor around the oil tank and oil cooler. A 250 gal (946 l) self-sealing fuel tank was fitted in the fuselage.[20] Standard armament on the F6F-3 consisted of six .50 in (12.7 mm) M2/AN Browning air-cooled machine guns with 400 rounds per gun. A center-section hardpoint under the fuselage could carry a single 150 gal (568 l) disposable drop tank, while later aircraft had single bomb racks installed under each wing, inboard of the undercarriage bays; with these and the center-section hard point late model F6F-3s could carry a total bomb-load in excess of 2,000 lb (900 kg). Six 5 in (127 mm) HVARs (High Velocity Aircraft Rocket) could be carried; three under each wing on "zero-length" launchers.[21][22]
Two night fighter sub-variants of the F6F-3 were developed: the 18 F6F-3E's were converted from standard -3s and featured the AN/APS-4 radar in a pod mounted on a rack beneath the right wing, with a small radar-scope fitted in the middle of the main instrument panel and radar operating controls installed on the port side of the cockpit.[23] The later F6F-3N, first flown in July 1943, was fitted with the AN/APS-6 radar in the fuselage, with the antenna dish in a bulbous fairing mounted on the leading-edge of the outer right wing; approximately 200 F6F-3Ns were built.[24] Hellcat night fighters claimed their first victories in November 1943.[25] A total of 4,402 F6F-3s were built through until April 1944, when production was changed to the F6F-5.[18]
An early production F6F-5 being tested with eight 5 in. HVAR rockets.
The F6F-5 featured several improvements including a more powerful R-2800-10W engine, embodying a water-injection system and housed in a slightly more streamlined engine cowling, spring-loaded control tabs on the ailerons, and an improved, clear view windscreen, with a flat armored-glass front panel replacing the F6F-3's curved plexiglass panel and internal armor glass screen.[10][18] In addition, the rear fuselage and tail units were strengthened, and, apart from some early production aircraft, the majority of the F6F-5's built were painted in an overall gloss sea blue finish.[26] After the first few F6F-5s were built, the small windows behind the main canopy were deleted.[27] The F6F-5N night fighter variant was fitted with an AN/APS-6 radar in a fairing on the outer-starboard wing. A small number of standard F6F-5s were also fitted with camera equipment for reconnaissance duties as the F6F-5P.[28] While all F6F-5s were capable of carrying an armament mix of one 20 mm (.79 in) M2 cannon in each of the inboard gun bays (220 rounds per gun), along with two pairs of .50 in (12.7 mm) machine guns (each with 400 rounds per gun), this configuration was only used on later F6F-5N night fighters.[29] The F6F-5 was the most common F6F variant, with 7,870 being built.[18]
Other prototypes in the F6F series included the XF6F-4 (02981, a conversion of the XF6F-1 powered by an R-2800-27 and armed with four 20mm M2 cannon) which first flew on 3 October 1942 as the prototype for the projected F6F-4. This version never entered production and 02981 was converted to an F6F-3 production aircraft.[30] Another experimental prototype was the XF6F-2 (66244), an F6F-3 converted to use a Wright R-2600-15, fitted with a Birman manufactured mixed-flow turbocharger, which was later replaced by a Pratt & Whitney R-2800-21, also fitted with a Birman turbocharger.[31] The turbochargers proved to be unreliable on both engines, while performance improvements were marginal. As with the XF6F-4, 66244 was soon converted back to a standard F6F-3.[32] Two XF6F-6s (70188 and 70913) were converted from F6F-5s and used the 18-cylinder 2,100 hp (1,567 kW) Pratt and Whitney R-2800-18W two-stage blower radial engine with water injection and driving a Hamilton-Standard four-bladed propeller.[33] The XF6F-6s were the fastest version of the Hellcat series with a top speed of 417 mph (671 km/h), but the war ended before this variant could be mass-produced.[10][34]
The last Hellcat rolled out in November 1945, the total production being 12,275, of which 11,000 had been built in just two years.[35] This high production rate was credited to the sound original design, which required little modification once production was underway.
[edit]Operational history
[edit]U.S. Navy and Marines
VF-82 Grumman F6F-5 ready for launch from USS Bennington off Okinawa in May 1945. The majority of the F6F-5s built were painted overall Glossy Sea Blue
The Hellcat first saw action against the Japanese on 1 September 1943 when fighters off the USS Independence shot down a Kawanishi H8K "Emily" flying boat.[36] Soon after, on 23 and 24 November, Hellcats engaged Japanese aircraft over Tarawa, shooting down a claimed 30 Mitsubishi Zeros for the loss of one F6F.[36] Over Rabaul, New Britain, on 11 November 1943, Hellcats and F4U Corsairs were engaged in day-long fights with many Japanese aircraft including A6M Zeros, claiming nearly 50 aircraft.[36]
When trials were flown against a captured Zero Type 52, they showed that the Hellcat was faster at all altitudes. The F6F outclimbed the Zero marginally above 14,000 ft and rolled faster at speeds above 235 mph. The Japanese fighter could out-turn its American opponent with ease at low speed and enjoyed a slightly better rate of climb below 14,000 ft. The trials report concluded:
“Do not dogfight with a Zero 52. Do not try to follow a loop or half-roll with a pull-through. When attacking, use your superior power and high speed performance to engage at the most favourable moment. To evade a Zero 52 on your tail, roll and dive away into a high speed turn.”[37]
Hellcats were the major U.S. Navy fighter type involved in the Battle of the Philippine Sea, where so many Japanese aircraft were shot down that Navy aircrews nicknamed the battle "the Great Marianas Turkey Shoot". The F6F accounted for 75% of all aerial victories recorded by the U.S. Navy in the Pacific.[38] Radar-equipped Hellcat night fighter squadrons appeared in early 1944.
U.S. Navy and Marine F6F pilots flew 66,530 combat sorties and claimed 5,163 kills (56% of all U.S. Navy/Marine air victories of the war) at a recorded cost of 270 Hellcats in aerial combat (an overall kill-to-loss ratio of 19:1 based on claimed but not confirmed kills).[39] The aircraft performed well against the best Japanese opponents with a claimed 13:1 kill ratio against the A6M Zero, 9.5:1 against the Nakajima Ki-84, and 3.7:1 against the Mitsubishi J2M during the last year of the war.[40] The F6F became the prime ace-maker aircraft in the American inventory, with 305 Hellcat aces. The U.S. successes were not only attributed to superior aircraft, but also from 1942 onwards, they faced increasingly inexperienced Japanese aviators as well as having the advantage of increasing numerical superiority.[N 6] In the ground attack role, Hellcats dropped 6,503 tons (5,899 tonnes) of bombs.[39]
The U.S. Navy preferred the more docile flight qualities of the F6F compared with the Vought F4U Corsair, especially during carrier takeoffs and landings, and the F6F remained the standard USN carrier-borne fighter until the F4U series was finally cleared for carrier operations in late-1944.[42] In addition to its good flight qualities, the Hellcat was easy to maintain and had an airframe tough enough to withstand the rigors of routine carrier operations.[43] Like the Wildcat, the Hellcat was designed for ease of manufacture and ability to withstand significant damage. The U.S. Navy's all-time leading ace, Captain David McCampbell USN (Ret), scored all his 34 victories in the Hellcat. He once described the F6F as "... an outstanding fighter plane. It performed well, was easy to fly and was a stable gun platform. But what I really remember most was that it was rugged and easy to maintain."[44]
During the course of World War II, 2,462 F6F Hellcats were lost to all causes; 270 in aerial combat, 553 lost to anti-aircraft ground and ship-board fire, and 341 were lost to operational causes. Of the total figure 1,298 were destroyed in training and ferry operations, normally outside of the combat zones.[45]
A section of Fleet Air Arm Hellcat F Mk.Is of 1840 Squadron in June 1944.
[edit]British use
The British Fleet Air Arm (FAA) received 1,263 F6Fs under the Lend-Lease Act; initially it was known as the Grumman Gannet Mark I. The name Hellcat replaced it in early 1943 for the sake of simplicity, the Royal Navy at that time adopting the use of the existing American naval names for all the U.S.-made aircraft supplied to it, with the F6F-3 being designated Hellcat F I, the F6F-5, the Hellcat F II and the F6F-5N, the Hellcat NF II.[N 7] They saw action off Norway, in the Mediterranean and in the Far East. A number were fitted with photographic reconnaissance equipment similar to the F6F-5P, receiving the designation Hellcat FR II.[46] The Pacific War being a naval war, the FAA Hellcats primarily faced land based aircraft in the European and Mediterranean Theaters,[47][48] and as a consequence experienced far fewer opportunities for air-to-air combat than their USN/Marines counterparts; they claimed a total of 52 enemy aircraft kills during 18 aerial combats from May 1944 to July 1945. 1844 Naval Air Squadron, on board HMS Indomitable of the British Pacific Fleet was the highest scoring unit, with 32.5 kills.[49]
FAA Hellcats, as with other Lend-Lease aircraft, were rapidly replaced by British aircraft after the end of the war, with only two of the 12 squadrons equipped with the Hellcat at VJ-Day still retaining Hellcats by the end of 1945.[50] These two squadrons were disbanded in 1946.[50]
Postwar service: A bright orange F6F-3K target drone
[edit]Postwar
Postwar, the Hellcat was succeeded by the F8F Bearcat, which was smaller, more powerful and more maneuverable, but entered service too late to see combat in World War II.[51] The Hellcat was used for second-line USN duties, including training. In late 1952, Guided Missile Unit 90 used F6F-5K drones, each carrying a 2000 lb bomb, to attack bridges in Korea; flying from USS Boxer, radio controlled from an escorting AD Skyraider.[52] The French Aéronavale was equipped with F6F-5 Hellcats and used them in Indochina. The Uruguayan Navy also used them until the early 1960s.[53]
[edit]Variants
[edit]XF6F prototypes
XF6F-1
First prototype, powered by a two-stage 1,600 hp (1,500 kW) Wright R-2600-10 Cyclone 14 radial piston engine.
XF6F-2
The first XF6F-1 prototype revised and fitted with a turbocharged Wright R-2600-16 Cyclone radial piston engine. R-2600 replaced by turbo-charged R-2800-21.
XF6F-2 showing the later R-2800-21 installation with Birman turbo-charger.
XF6F-3
Second prototype fitted with a two-stage supercharged 2,000 hp (1,500 kW) Pratt & Whitney R-2800-10 Double Wasp radial piston engine.
XF6F-4
One F6F-3 fitted with a two-speed turbocharged 2,100 hp (1,567 kW) Pratt & Whitney R-2800-27 Double Wasp radial piston engine.
XF6F-6
Two F6F-5s that were fitted with the 2,100 hp (1,566 kW) Pratt & Whitney R-2800-18W radial piston engine, and four-bladed propellers.
[edit]Series production
F6F-3 (British designations Gannet Mk. I then Hellcat Mk. I)
Single-seat fighter, fighter-bomber aircraft, powered by a 2,000 hp (1,500 kW) Pratt & Whitney R-2800-10 Double Wasp radial piston engine.
F6F-3E
Night fighter version, equipped with an AN/APS-4 radar in a fairing on the starboard outer wing.
F6F-3N
Another night fighter version, equipped with a newer AN/APS-6 radar in a fairing on the starboard outer wing.
F6F-5 Hellcat (British Hellcat Mk. II)
Improved version, with a redesigned engine cowling, a new windscreen structure with an integral bulletproof windscreen, new ailerons and strengthened tail surfaces; powered by a 2,200 hp (1,640 kW) Pratt & Whitney R-2800-10W (-W denotes Water Injection) radial piston engine.
F6F-5K Hellcat
A number of F6F-5s and F6F-5Ns were converted into radio-controlled target drones.
F6F-5N night fighter with AN/APS-6 radar and 2 20mm M2 cannon.
F6F-5N Hellcat (British Hellcat N.F. Mk II)
Night fighter version, fitted with an AN/ APS-6 radar. Some were armed with two 20 mm (0.79 in) AN/M2 cannon in the inner wing bays and four 0.50 in (12.7 mm) M2 Browning machine guns in the outer.
F6F-5P Hellcat
Small numbers of F6F-5s were converted into photo-reconnaissance aircraft, with the camera equipment being fitted in the rear fuselage.
Hellcat FR Mk II
This designation was given to British Hellcats fitted with camera equipment.
FV-1
Proposed designation for Hellcats to be built by Canadian Vickers; cancelled before any built.[54]
[edit]Operators
France
French Navy
United Kingdom
Royal Navy
United States
United States Navy
Uruguay
Uruguayan Navy
F6F-5 GC 2/6 normandie niemen
F6F-5 VF83
F6F-3 VF27
F6F-5 Flottille 1F
Survivors
A relatively large number of Grumman F6Fs are survivors, either in museums or in flyable condition. In order of Bu.No. they are:[55]
[edit]United Kingdom
Airworthy
F6F-5K Hellcat, BuNo. 80141 is flightworthy and owned by The Fighter Collection in Duxford.[56]
On display
F6F-5 Hellcat, BuNo. 79779 is on display at the Fleet Air Arm Museum in RNAS Yeovilton.[57]
[edit]United States
Chino Warbirds' F6F-3 painted as a Fleet Air Arm Hellcat Mk. I.
Airworthy
F6F-3 Hellcat, BuNo. 41930 is flightworthy and owned by Chino Warbirds Inc. in Houston, Texas.[58]
F6F-5 Hellcat, BuNo. 70222 is flightworthy and owned by Commemorative Air Force (Southern California Wing) in Camarillo, California.[59]
F6F-5 Hellcat, BuNo. 78645 is flightworthy and owned by the Yanks Air Museum in Chino, California.[60]
F6F-5K Hellcat, BuNo. 79683 is flightworthy and owned by the Kalamazoo Aviation History Museum in Kalamazoo, Michigan.[61]
F6F-5 Hellcat, BuNo. 79863 is flightworthy and owned by Vulcan Warbirds Inc., hangared at the Flying Heritage Collection in Everett, Washington.[62]
F6F-5N Hellcat, BuNo. 94204 is flightworthy and owned by Lone Star Flight Museum in Galveston, Texas.[63]
F6F-5N Hellcat, BuNo. 94473 is flightworthy and owned by Palm Springs Air Museum in Palm Springs, California.[64]
On display
F6F-3 Hellcat, BuNo. 41476 is on display at the Evergreen Aviation & Space Museum in McMinnville, Oregon. It is on loan from the National Museum of the Marine Corps in Triangle, Virginia.[65]
F6F-3K Hellcat, BuNo. 41834 is on display at the National Air and Space Museum in Washington D.C..[66]
F6F-3 Hellcat, BuNo. 42874 is on display at the San Diego Aerospace Museum in San Diego, California.[67]
F6F-5 Hellcat, BuNo. 66237 is on display at the National Museum of Naval Aviation in Pensacola, Florida.[68]
F6F-5K Hellcat, BuNo. 77722 is on display at Joint Base Andrews Naval Air Facility in Maryland.[69]
F6F-5K Hellcat, BuNo. 79192 is on display at the New England Air Museum in Windsor Locks, Connecticut.[70]
F6F-5K Hellcat, BuNo. 79593 is on display at the USS Yorktown/Patriots Point Naval & Maritime Museum in Mount Pleasant, South Carolina.[71]
F6F-5 Hellcat, BuNo. 94203 is on display at the National Museum of Naval Aviation in Pensacola, Florida.[72]
F6F-5K Hellcat, BuNo. 94263 is on display at the Cradle of Aviation Museum in New York. It is on loan from the USMC Museum in Quantico, Virginia.[73]
Under restoration
F6F-3 Hellcat, BuNo. 25910 is under restoration at the National Museum of Naval Aviation in Pensacola, Florida after being retrieved from Lake Michigan in 2009.[74]
F6F-3 Hellcat, BuNo. 40467 is under restoration at Yanks Air Museum in Chino, California.[75]
F6F-3 Hellcat, BuNo. 43041 is under restoration to airworthy condition at Fantasy of Flight in Polk City, Florida.[76]
F6F-5 Hellcat, BuNo. 70185 is under restoration at the Quonset Air Museum in Quonset Point, Rhode Island.[77]
[edit]Specifications (F6F-5 Hellcat)
An F6F-5 flown by Air Group Commander (CAG), Cdr. Louis H. Bauer of Carrier Air Group 3 (CVG-3), leads a formation of CVG-3 aircraft in 1946.
Data from Quest for Performance,[78]Jane’s Fighting Aircraft of World War II[79]Standard Aircraft Characteristics[80]
General characteristics
Crew: 1
Length: 33 ft 7 in (10.24 m)
Wingspan: 42 ft 10 in (13.06 m)
Height: 13 ft 1 in (3.99 m)
Wing area: 334 ft² (31 m²)
Airfoil: NACA 23015.6 mod root; NACA 23009 tip
Empty weight: 9,238 lb (4,190 kg)
Loaded weight: 12,598 lb (5,714 kg)
Max. takeoff weight: 15,415 lb (6,990 kg)
Powerplant: 1 × Pratt & Whitney R-2800-10W "Double Wasp" two-row radial engine with a two-speed two-stage supercharger, 2,000 hp (1,491 kW[81])
Propellers: 3-blade Hamilton Standard
Propeller diameter: 13 ft 1 in (4.0 m)
*Fuel capacity: 250 gal (946 L) internal; up to 3 × 150 gal (568 L) external drop tanks
Zero-lift drag coefficient: 0.0211
Drag area: 7.05 ft² (0.65 m²)
Aspect ratio: 5.5
Performance
Maximum speed: 330 kn (380 mph, 610 km/h)
Stall speed: 73 kn (84 mph, 135 km/h)
Combat radius: 820 nmi (945 mi, 1,520 km)
Ferry range: 1,330 nmi (1,530 mi, 2,460 km)
Service ceiling: 37,300 ft (11,370 m)
Rate of climb: 3,500 ft/min (17.8 m/s)
Wing loading: 37.7 lb/ft² (184 kg/m²)
Power/mass: 0.16 hp/lb (260 W/kg)
Time-to-altitude: 7.7 min to 20,000 ft (6,100 m)
Lift-to-drag ratio: 12.2
Takeoff roll: 799 ft (244 m)
Armament
Guns:
either 6× 0.50 in (12.7 mm) M2 Browning machine guns, with 400 rounds per gun, (All F6F-3, and most F6F-5)
or 2 × 0.79 in (20 mm) cannon, with 225 rounds per gun
and 4 × 0.50 in (12.7 mm) Browning machine guns with 400 rounds per gun (F6F-5N only)
Rockets:
6 × 5 in (127 mm) HVARs or
2 × 11¾ in (298 mm) Tiny Tim unguided rockets
Bombs: up to 4,000 lb (1,814 kg) full load, including:
Bombs or Torpedoes:(Fuselage mounted on centreline rack)
1 × 2,000 lb (907 kg) bomb or
1 × Mk.13-3 torpedo;
Underwing bombs: (F6F-5 had two additional weapons racks either side of fuselage on wing centre-section)
2 × 1,000 lb (450 kg) or
4 × 500 lb (227 kg)
8 × 250 lb (110 kg)
Editado pela última vez por Lessa em 13 Jan 2014, 10:35, em um total de 3 vezes.
Razão: Título ajustado.
Seu Madruga
Re: F6F-5 Hobby Boss 1/48
Opá!! Sou o primeiro da fila!!
Tem lugar pra mais um!?????
Acompanhando! :shock: :shock: :shock:
Ricardo almeida
Registrado em: 20 Out 2012, 18:54
Nome: Carlos Ricardo Aleida
Mensagem por Ricardo almeida »
Mais um gato do inferno para nossa galeria !!!
gomidefilho
Registrado em: 09 Jul 2012, 17:33
Nome: Péricles Lopes Gomide Filho
GT 04 - Aviação Militar Brasileira - Montagem: Nieuport 21E1 - Av. Militar - 1/100 Models by Marek GT 09 - Century Series - Montagem: F-100 Super Sabre - Der Kampfflieger - 1/100 GT 11 - Maquinas Voadoras Russas - Montagem: MiG-15 Fagot - Oddball - 1/100 GT 11 - Maquinas Voadoras Russas - Montagem: Mikoyan Gurevich MiG-3 - Modelart - 1/100 GT 11 - Maquinas Voadoras Russas - Montagem: Tsybin NM-1 - Oddball - 1/100 GT 11 - Maquinas Voadoras Russas - Montagem: Mikoyan Gurevich MiG-21U-400 "Mongol A" - 1/100 - Café Papermodel GT 12 - Navy - Montagem: Martin 139 WAN - Fiddlers Green - 1/100 GT 24 - Batalha da Inglaterra - Montagem: Heinkel He 59 - Murph's Models - 1/100 GT 29 - Bombardeiros - Montagem: Tupolev TB-3 (Zveno Aviamatka) - Murphs Models - 1/100 GT 29 - Bombardeiros - Montagem: Douglas B-18A Bolo - Murph's Models - 1/100 GT 31 - Armas do Sol Nascente - Montagem: Kyushu K11W1 Shiragiku  Ned Reif Papermodel 1/100 GT 47 - Vietnam War - Montagem: DHC Beaver U-6 - DGA Papermodel - 1/100 GT 51 - Primeira Guerra Mundial - Montagem: Fokker Dr I - Der Kampfflieger - papermodel 1/100
GT 40 - Royal Air Force (RAF) - Montagem: Airco DH-10 -Lad n Dad- 1/100 - papermodel GT 40 - Royal Air Force (RAF) - Montagem: Fairey Flycatcher - Wings of Horus - 1/100 - papermodel GT 47 - Vietnam War - Montagem: DHC C-7 Caribou - Murph's Models 1/100 papermodel GT 51 - Primeira Guerra Mundial - Montagem: Felixtowe F2A Late - Scissors and Planes - Papermodel - 1/100 GT 51 - Primeira Guerra Mundial - Montagem: Ansaldo SVA-5 - Fiddlers Green - 1/100 - Papermodel
Mensagem por gomidefilho »
Acompanhando com grande interesse...
Retornando à ativa...
Esse kit é muito bom! Já montei um como o Minsi III do David McCampbell, o ás dos ases da US Navy na II Guerra, uma das versões possíveis com o kit.
É uma pena que ele tem um motor bem detalhado que, quando colocado o cowling, fica 80% escondido! :raiva:
Vai fazê-lo com as asas dobradas ou abertas? :pensando:
Olha aí o Minsi III, para te ajudar!
Editado pela última vez por Hartmann em 14 Fev 2013, 23:01, em um total de 1 vez.
kogyro
Obrigado pela visita pessoal.
Hartmann irei montar ele com as asas abertas e tentar não colar o cooling para deixar o motor exposto quando aberto.
Mas tem uma coisa que me intriga, os porões do trem de pouso são em azul ou o amarelo exterior:?
Seu Madruga
kogyro escreveu:Obrigado pela visita pessoal.
O meu eu pintei os interiores em Zinc Chromate e as pernas dos trens de pouso em Semigloss Blue (assim como resto do avião), mas só depois verifiquei que eram em azul em algumas referências. Outras mostram o interior em Zinc Chromate, com as pernas do trem de pouso, em branco, inclusive o desenho que postei acima. Acho que esse padrão é o mais provável: interior do cowling do motor, parte interna das portas e baias dos trens de pouso em Zinc Chromate, assim como as partes internas das asas, pernas dos trens de pouso em branco e interior do Cockpit em interior green. Todas as demais partes externas no mesmo Semigloss Blue da fuselagem.
Hartmann escreveu:
Valeu Hartmann, sua explicação me ajudou também!!
kogyro
pois é hartmann, irei fazer com essa coloração mesmo no trem de pouso e nos porões, será que para a cor desse avião o Insignia blue daria conta do recado?
Pesquisei pelo navy blue e encontro somente uma cor como um azul celeste.
Seu Madruga
Voltar para “GT 12 - Navy”
