[Concluído]  de Havilland Vampire T.11 - Airfix A02058 - 1/72
CCRider
Nome: Gustavo Sarmento
Agradeceu: 9 vezes
Curtiram: 7 vezes
Mensagem por CCRider »
Buenas e me espalho!
Vamos dar início a mais um GT, entonces. Inicialmente, apenas colocarei o histórico para cumprir as normas de fundador de GT. Assim que possível, inicio a montagem (tenho outros GTs na mesma situação, e meu plano é concluir todos no decorrer de 2019).
Infelizmente, o histórico será em inglês mesmo, pois não encontrei online material em português à altura.
The de Havilland Vampire is a British jet fighter developed and manufactured by the de Havilland Aircraft Company. It had the distinction of being the second jet fighter to be operated by the RAF, after the Gloster Meteor, and the first to be powered by a single jet engine.
Work on the Vampire commenced during 1941 in the midst of the Second World War; it was initially intended as an experimental aircraft, albeit one that was suitable for combat, that harnessed the groundbreaking innovation of jet propulsion. Out of the company's design studies, it was quickly decided to settle on a single-engine, twin-boom aircraft, powered by the Halford H.1 turbojet engine (later produced as the "Goblin").
de Havilland Goblin
Aside from its propulsion system and twin-boom configuration, it was a relatively conventional aircraft. Despite being originally ordered as an experimental aircraft only, during May 1944, it was decided to mass-produce the aircraft as an interceptor for the Royal Air Force (RAF). During 1946, the first production Vampire entered operational service with the RAF, only months after the conflict had come to an end.
The Vampire quickly proved to be an effective aircraft and was adopted as a replacement for many wartime piston-engined fighter aircraft. During its early service, it was recognised for accomplishing several aviation firsts and various records, such as being the first jet aircraft to traverse the Atlantic Ocean. The Vampire remained in front-line service with the RAF up until 1953; after this date, it was progressively reassigned to various secondary roles, such as ground attack missions and pilot training operations, for which specialist variants of the type were produced. During 1966, the Vampire was officially retired by the RAF, having been withdrawn from its final role as an advanced trainer after having been replaced by the Folland Gnat. The Royal Navy had also adopted the type as the Sea Vampire, a navalised variant suitable for operations from its aircraft carriers. It was the service's first jet fighter.
The Vampire had been exported to a wide variety of nations and was operated across a plethora of theatres and climates across the world. Several countries deployed the type in combat during several conflicts, including the Suez Crisis, the Malayan Emergency, and the Rhodesian Bush War. By the end of production, almost 3,300 Vampires had been manufactured, a quarter of these having been manufactured under licence in several other countries. In addition, de Havilland pursued the further development of the type; major derivatives produced include the DH.115, a dedicated dual-seat trainer, and the more advanced DH.112 Venom, a refined variant furnished with a swept wing (instead of the straight wing of the Vampire) and orientated towards conducting ground attack and night fighter operations.
The final variants of the Vampire was the T (trainer) aircraft. Being first flown from the old Airspeed Ltd factory at Christchurch, Hampshire on 15 November 1950, production deliveries of the Vampire trainer began in January 1952. Over 600 examples of the T.11 were produced at Hatfield and Chester and by Fairey Aviation at Manchester Airport. By 1965, the Vampire trainer had been mostly withdrawn, its replacement in the advanced training role being the Folland Gnat; only a small number of Vampire T.11s remained in service, typically for the training of foreign students until these were too were retired in 1967.
A small number of aircraft that were used in secondary roles carried on in these capacities until the withdrawal of the last operational aircraft from service with No. 3 Civilian Anti-Aircraft Co-operation Unit at Exeter at the end of 1971. A single aircraft continued to be flown and remained in official service with the RAF as part of the "Vintage Pair" display team (along with a Gloster Meteor); however, this aircraft was lost as a result of a crash in 1986.
Fonte.
CCRider
Agradeceu: 9 vezes
Curtiram: 7 vezes
Re: de Havilland Vampire T.11 - Airfix A02058 - 1/72
Aproveitando o raro dia de folga este mês, vamos aproveitar e apresentar o kit.
Trata de um dos exemplares "new tooling" da Airfix, parte de uma bem sucedida linha cujo objetivo é redimir a "fama" da marca em relação a seus lançamentos mais antigos (via de regra, porcarias).
A qualidade da injeção é muito boa. O baixo relevo é profundo, como de costume neste fabricante. Ajuda pra caramba o washing, porém em detrimento de um pouco do realismo, especialmente em modelos pequenos como este.
Folha de decais e máscara para pintura do cockpit (esta, um aftermarket que acompanhou minha compra). Ótima qualidade, dentro do esperado em decais contemporâneos.
Manual de montagem. Denso, mas de fácil entendimento.
Esquemas de pintura sugeridos. Provavelmente farei o primeiro.
Bem... por ora é isso. Espero começar a montagem o quanto antes! :tchau:
GT 00 - Viva a Liberdade - Montagem: MiG-29 "The Swifts" - 1:144 - Revell GT 02 - F4 Phantom - Montagem: F-4E Phantom II - Academy - 1/144 GT 02 - F4 Phantom - Montagem: F-4E Phantom II - Academy - 1/144 GT XX - Inacabados & Restauração - Montagem: U.S. Navy LST Landing Craft - Testors - 1:613 GT XX - Inacabados & Restauração - Montagem: Resgate no Paredão Noroeste - 1/35 GT XX - Inacabados & Restauração - Montagem: Porta aviões - Revell - 1/700 GT 05 - Modelos Famosos - Montagem: F117 A Stealth Fighter - Revell - 1/144 GT 06 - Militaria "Buzão" - Montagem: Monty's Caravan - Revell - 1:76 GT 07 - Amigo Secreto - Montagem: Panzer II Ausf B - Dragon 1/144 (2014) GT 07 - Amigo Secreto - Montagem: Panzer III Ausf. E - Dragon 1/144 (2014) GT 08 - Trucks Militares - Montagem: Pak 40 75mm Anti-tank Gun & Truck - Airfix - 1/76 GT 10 - Figuras - Montagem: North American Black Bear & Cubs - Atlantis - 1/12 GT 10 - Figuras - Montagem: Avanço Lento - Figura Genérica - 1/35 GT 10 - Figuras - Montagem: Destruidor - Impressão 3D - sem escala GT 10 - Figuras - Montagem: Estátua Feminina - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Estátua Leão (Musei Capitolini) - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Estátua Leão (Kerepesi Cemetery) - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Agnes - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: Hulk - Impressão 3D - Sem escala GT 10 - Figuras - Montagem: American Eagle - Lindberg - 1/6 GT 10 - Figuras - Montagem: The Batman (Busto) - 1/4 GT 11 - Maquinas Voadoras Russas - Montagem: Suchoj S-37 Berkut - Revell - 1/144 GT 13 - Pendurados no Pincel - Montagem: F4U-1A Corsair - Revell - 1/72 GT 14 - Artilharias - Montagem: 105mm Howitzer - Testors/Italeri - 1/35 GT 16 - Debaixo D'agua - Montagem: USS Balao SS-285 - Hobby Boss - 1/700 GT 17 - Ficção Científica - Montagem: Baby Groot - scratch building - 1/1 GT 20 - Guerra no Deserto - Montagem: US 1/4 ton 4x4 M38A1C - Skybow - 1/35 GT 26 - Carros de Fórmula - Montagem: Lotus 79 - Nitto - 1/28 GT 27 - Aviação Civil - Montagem: Boeing 737-200 British Airways - Revell - 1/200 GT 29 - Bombardeiros - Montagem: Horten Go 229 - Revell 1/72 GT 29 - Bombardeiros - Montagem: B-25G Mitchell - Academy - 1/144 GT 32 - Tornado - Montagem: Tornado ECR TigerMeet - Revell - 1/144 GT 36 - Marines - Montagem: F/A-18C Hornet - Revell - 1/144 GT 37 - USAF - Montagem: F-15 Eagle - Academy - 1/144 GT 38 - Luftwaffe - Montagem: F-104 G Starfighter - Revell - 1/144 GT 39 - Protótipos - Montagem: Salt Flat Racers Turbo Go - Testors - 1/32 GT 39 - Protótipos - Montagem: SpaceShipTwo & WhiteKnightTwo - Revell - 1/144 GT 42 - Carros Americanos - Montagem: Sting Ray III - Revell - 1/25 GT 42 - Carros Americanos - Montagem: Chevy Corvette Coupe 2012 - AMT - 1/25 GT 43 - Navio a Vela - Montagem: Optimist Sailboat - Scratchbuilding - 1/25 GT 44 - STAR WARS 2015 - Montagem: R2-D2 - Metal Earth - 1/12 GT 44 - STAR WARS 2015 - Montagem: X-Wing - sem escala - Brinde Genérico GT 44 - STAR WARS 2015 - Montagem: Jedi Starfighter - Bandai - sem escala GT 44 - STAR WARS 2015 - Montagem: Star Wars First Order TIE Fighter Set - Bandai - sem escala GT 45 - Blindados na WWII - Montagem: White Half-track M3A1 & 1 Ton trailer - Airfix - 1/76 GT 46 - Guerra ao Terror - Montagem: EA-6B Prowler - Hasegawa - 1/72 GT 47 - Vietnam War - Montagem: Mig-21 Fishbed - Academy - 1/72 GT 48 - Carros Europeus - Montagem: Ferrari 360 Modena Spyder - Revell - 1/24 GT 49 - Pinturas e Camuflagens 'What if?' - Montagem: Mistel 5 - He162-A2 w/Arado E377-a - Dragon - 1/72 GT 51 - Primeira Guerra Mundial - Montagem: Nieuport N.28 C-1 - Revell - 1/72 GT 50 - The Fifties - Montagem: Fiat G.91R - Airfix - 1/72 GT 52 - Tudo o que sua imaginação permitir - Montagem: Sabriali Interceptor Mk I - Scratch - 1:72 GT 52 - Tudo o que sua imaginação permitir - Montagem: Ferrari 360 Modena Spyder (Autobot) - Revell - 1/24 GT 52 - Tudo o que sua imaginação permitir - Montagem: Mjölnir - Papercraft e Scratchbuilding - s/ escala GT 52 - Tudo o que sua imaginação permitir - Montagem: Drone - Scratchbuilding - 1/1 GT 52 - Tudo o que sua imaginação permitir - Montagem: Lightsaber Mestre Jedi Niellos - scratchbuilding - 1/4 GT 52 - Tudo o que sua imaginação permitir - Montagem: Lightsaber Mestre Jedi Sim-1 - scratchbuilding - 1/4 GT 52 - Tudo o que sua imaginação permitir - Montagem: Halo Commander Sarah Palmer - Bandai - Sem Escala GT 52 - Tudo o que sua imaginação permitir - Montagem: Sv-262Hs Draken III - Bandai - 1/144 GT 52 - Tudo o que sua imaginação permitir - Montagem: VF-31J Siegfried - Bandai - 1/144 GT 52 - Tudo o que sua imaginação permitir - Montagem: Grogu - Impressão 3D - Sem Escala GT 52 - Tudo o que sua imaginação permitir - Montagem: Iron Man Helmet - Impressão 3D - Sem Escala GT 52 - Tudo o que sua imaginação permitir - Montagem: SVD Rifle (Dragunov) - Platz - 1/12 GT 52 - Tudo o que sua imaginação permitir - Montagem: Howa Type 89 Rifle - Platz - 1/12 GT 52 - Tudo o que sua imaginação permitir - Montagem: M4A1 Rifle - Platz - 1/12 GT 53 - Pacific - Montagem: F4U-1 - Academy - 1/72 GT 54 - RAAF - Royal Australian Air Force - Montagem: BAE Hawk Series Mk. 100 - Italeri - 1/72 GT 55 - Harrier - Montagem: AV-8B Harrier II Plus - Revell - 1/144 GT 58 - Aces High - Montagem: Yak 1 (Lydia Litvyak) - ZTS - 1/72 GT 59 - SAR - Search and Rescue - Montagem: A-109 K2 Rega - Revell - 1/72 GT 59 - SAR - Search and Rescue - Montagem: Resgate no Paredão Noroeste - Diorama - 1/35 GT 59 - SAR - Search and Rescue - Montagem: Brincadeira ou Diversão - Diorama - 1/35 GT 59 - SAR - Search and Rescue - Montagem: Us-2 - Platz - 1/300 GT 59 - SAR - Search and Rescue - Montagem: Us-1/1a - Platz - 1/300 GT 59 - SAR - Search and Rescue - Montagem: Silverado CK 99 - Revell - 1/25 GT 60 - GT Ferrari - Montagem: Ferrari 512 S - Union - 1/24 GT 63 - Porta Aviões - Montagem: Shinano - Revell - 1/1200 GT 65 - F-14 Tomcat - Montagem: F-14 - Academy - 1/144 GT 67 - Grandes Modelos - Montagem: Samurai Sword - Doyusha - 1/3 GT 91 - Cenas e Impressões - Montagem: Em Busca de Sombra e Água Fresca -  Sem escala GT 91 - Cenas e Impressões - Montagem: O Homem Que Puxava o Gatilho - 1/35 GT 69 - Piores Goiabas Possíveis - Montagem: Supermarine Spitfire Mk XVI E - Heller - 1/72 GT 71 - Carros alemães - Montagem: VW Buggy - Revell - 1/32 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: M998 Desert Patrol - Italeri - 1/35 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: Daimler Dingo Scout Car - Revell - 1/76 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: Sd.Kfz.234/2 "Puma" - Roden - 1/72 GT 72 - BLINDADOS MILITARES SOBRE RODAS - Montagem: Autoblinda AB 43 - Italeri - 1/72 GT 73 - F-16 Viper - Montagem: F-16 Fighting Falcon - Academy - 1/144 GT 74 - Duas Rodas - Montagem: Vespa Futurista P.Mk1 - Scratchbuilding - S/escala GT 75 - Embarcações - Montagem: JMSDF Harushio Class - Hobby Boss - 1/700 GT 75 - Embarcações - Montagem: Jangada - "Gravetobuilding" - Sem escala GT 75 - Embarcações - Montagem: Ship in The Bottle (Goleta) - Madeira Balsa - Sem Escala GT 75 - Embarcações - Montagem: Arca de Noé - Madeira Balsa - 1/500 GT 75 - Embarcações - Montagem: USS Balao SS-285 - Hobby Boss - 1/700 GT 75 - Embarcações - Montagem: Longboard - scratch building - S/escala GT 75 - Embarcações - Montagem: PLA Navy Type 039A - Hobby Boss - 1/700 GT 76 - Carros Orientais - Montagem: Lexus Zent Cerumo – Bandai – 1/43 GT 76 - Carros Orientais - Montagem: Mobil 1 SC - Bandai - 1/43 GT 77 - F-15 Eagle - Montagem: F-15 Eagle - Academy - 1/144 GT 78 - Corvette - Montagem: Chevy Corvette Coupe 2012 - AMT - 1/25 GT 79 - Aeronaves torpedeiras - Montagem: Aichi M6A1-K Nanzan (Seiran Kai) - Tamiya - 1/72 GT 80 - Forças Aéreas Desconhecidas - Montagem: Aero L-29 Delfin - Egito - Mark I Models - 1/144 GT 80 - Forças Aéreas Desconhecidas - Montagem: Mig-21 - Czech Air Force - Eduard - 1/144 GT 81 - Aeronaves de treinamento - Montagem: Zlín Z-42M - HobbyBoss - 1/72 GT 81 - Aeronaves de treinamento - Montagem: Folland Gnat T.1 - Airfix - 1/72 GT 82 - Transportes e Serviços - Montagem: Bedford QLT - Airfix - 1:76 GT 82 - Transportes e Serviços - Montagem: Bedford QLD - Airfix - 1:76 GT 82 - Transportes e Serviços - Montagem: Bike Tuk Tuk - Scratchbuilding - 1/76 GT 83 - Art Attack - Acrilex Challenge - Montagem: F-15 Eagle Strike - Revell - 1/144 GT 84 - Aeronaves do Bureau Mikoyan-Gurevich (MiG) - Montagem: Mig-15 - Eduard - 1/72 GT 85 - Guerra das Falklands/Malvinas - Montagem: LWB Landrover and Trailer - Airfix - 1/76 GT 87 - Força Aérea Italiana - Montagem: Macchi MC.200 - Sweet - 1/144 (373ª Esquadrilha; 153 grupo 1941) GT 90 - Blindados sobre lagartas - Montagem: Pz. IV Ausf.F2 - Dragon - 1/144 GT 90 - Blindados sobre lagartas - Montagem: Hornisse - Dragon - 1/144 GT 92 - ThunderBolt (Guilherme Augusto Sorrenti) - Montagem: A-10 Thunderbolt II - Revell - 1/144 GT 94 - Plasti*Brasil 10 Anos - Montagem: Pz. IV Ausf.F2 + Hornisse - Dragon - 1/144 [Mini Diorama]
Acompanhando!
pedro neto
Registrado em: 26 Mai 2013, 16:23
Nome: Pedro Gomes da Silva Neto
Mensagem por pedro neto »
uia.... esse kit é massa!!!!!!!!! é tao bom q monta rapidim...... levei 3 semanas no meu... so no carnaval montei ele todo e fficou so a pintura p depois.. acompanhando
Tem coisas que só o Pedrão faz por você!
Correia
Nome: Ronaldo Magalhães
Curtiram: 54 vezes
Mensagem por Correia »
Acompanhando.
Enviado de meu SM-A720F usando o Tapatalk
Chegando para acompanhar.
CCRider
Agradeceu: 9 vezes
Curtiram: 7 vezes
Atualizando o tópico para ajudar a manter o GT ativo:
Ainda não comecei a montagem deste (será o seguinte, assim que concluir o Phantom). Sendo assim, sem maiores novidades na montagem.
Porém, recentemente arrematei uns aftermarkets, e dentre eles um par de assentos ejetáveis Martin-Baker Mk 4 em resina:
Não encontrei informações definitivas se o Vampire T.11 usava o Mk 3 ou o Mk 4. De qualquer maneira, provavelmente colocarei estes nele. :thumbup:
Valeu Rider!
Esses assentos parecem altamente detalhados, será uma ótima adição ao modelo! :thumbup:
ArmouredSprue
Nome: Paulo Castro
Mensagem por ArmouredSprue »
Show de bola. Tenho esse kit em estoque, vou acompanhar sua montagem, quem sabe assim me animo também.
Boa sorte
Cheers mates!
Paulo
ArmouredSprue Blog
SCALEMATES PROFILE
Voltar para “GT 81 - Aeronaves de treinamento”
