Tintas Conversion
Fórum dedicado a documentos relacionados ao Plastimodelismo
Moderador: Moderadores Multimidia
massruha
Nome: César Vinicíus
Tintas Conversion
Mensagem por massruha »
Pessoal, boa tarde.
Achei um doc interessante. Me ajuda bastante.
http://www.e-kalfakis.gr/userfiles/file ... 0CHART.pdf
Acredito que para os novatos isso é uma mão na roda :D :D :D :D
t+.
Re: Tintas Conversion
massruha escreveu:Pessoal, boa tarde.
t+.
Muito bom!!! Obrigado por compartilhar Cesar!!! :thumbup: :thumbup:
massruha
Amigo achei mais umas referencias, segue
RLM - Colors of the German Luftwaffe
http://www.rlm.at/cont/archiv01_e.htm
massruha escreveu:Amigo achei mais umas referencias, segue
Interessante a sessão onde fala sobre o efeito escala:
the scale-effect:
An additional aspect of determination of shades of colors is the scale effect. Every model reflects because of its smaller size less light then the original. Therefore a model painted with original colors looks always too dark. To avoid this effect we can mix to every color a higher amount of white. At this topic there are many different opinions.
The amount of white can be calculated by the following formula:
Scale : 2 = % of white has to be added to the basic color
Example:1:72 > 72:2 = 36% white to be added, 1:32 > 32:2 = 16% white to be added
This formula can not be adopted for big (1:24) and small scales (from 1:144 and higher). At the scale of 1:24 you can abstain from adding white. The formulas mentioned above are often published. They are also published in The Official Monogram Painting Guide to German Aircraft. This book is in Europe and in the States quite common.
British modellers prefer it a little bit darker, formulas from Ian Huntley:
1:32 - 7%, 1:48 - 10%, 1:72 - 15%, 1:144 - 23%
(from: Ian Huntley - Scale Aircraft modelling Vol. 5 / # 10)
Kyosanin
Nome: Tanderson Morales
Curtiram: 12 vezes
Mensagem por Kyosanin »
Boa Massruha!!
Já vai pra parede do lado da bancada.. essas tabelas são sempre úteis!
massruha
Kyosanin escreveu:Boa Massruha!!
Bem isso mesmo, é sempre bom deixar a vista!!!!
Robson
Registrado em: 05 Jan 2015, 22:08
Nome: Robson Ezequiel
Mensagem por Robson »
t+.
Muito obrigado! material importantissimo para iniciantes!!
Valeu mesmo! :thumbup:
VictorSalomão
Acabei de Chegar
Registrado em: 29 Jul 2020, 12:44
Mensagem por VictorSalomão »
t+.
Teria como atualizar o link?
Obrigado.
Voltar para “Documentos”
