[Expositor] TIRPITZ COURAÇADO 1944 TAMIYA 1/350*** FINALIZADO***
Moderador: Moderadores Naval
- torrezani21
- Registrado em: 08 Ago 2012, 10:12
- Nome: carlos alberto torrezani
Boas pessoal,depois de uns dias parado devido a um probleminha em meu braços esquerdo ,volto com este couraçado de história da WWII.
Comecei ele semana passada,devido minha limitações do lado esquerdo não tirei fotos das arvores do kit,só comecei a documentar esta semana,peço desculpas , mas o que vale é mostrar o andamento da montagem e extras que por sua vez ( os viciados em scratch) kkkk, como eu sempre arranjam um jeito de melhorar o kit e ganhando mais experiência.
ESPECIFICAÇÕES DA EMBARCAÇÃO
General Details
Name of the ship Bismarck Tirpitz
Builder Blohm & Voss, Hamburg Kriegsmarine Werft, Wilhelmshaven
Builder's number BV 509 S-128
Contract placed 16. November 1935 14. June 1936
Laid down 1. July 1936 2. November 1936
Launched 14. February 1939 1. April 1939
Commissioned 24. August 1940 25. February 1941
Disposition Sunk in action with superior British force, 27. May 1941, at 48º 10´ north, 16º 12´ west. 2106 men lost, 115 survivors (110 captured). Sunk in Sørbotn near Tromsø by British aircraft on 12. November 1944, at 69°36´ North and 18°59´ East. 971 men lost. 1948-1957 partially salvaged by British, Norwegian and German firms.
Displacement
Measurement
(gross or net registered tons) 28.181 grt
11.110 nrt 28.160 grt
Displacement: (August 1940) (February 1941)
empty 39.517 tonnes 39.539 tonnes
designed 45.451 tonnes 45.474 tonnes
full 49.406 tonnes 49.429 tonnes
maximum 50.405 tonnes 50.425 tonnes
(53.500 tonnes 1944)
Dimensions and Construction Details
Length Overall 250,5 m 253,6 m
Length, cwl (construction waterline) 241,55 m 241,72 m
Beam, cwl (construction waterline) 36 m 36 m
Designed draught 9,33 m 9,9 m
Maximum draught 10,2 m
(at 49.406 tonnes) 10,61 m
(at 52.890 tonnes)
Height of side (measured from keel top edge to upper deck) 15 m 15 m
Freeboard, amidships 5,67 m 5,67 m
Freeboard, forward 8,8 m 8,8 m
Building steel ST 52 ST 52
Watertight compartments XXII XXII
Immersion per cm +57,3 tonnes +57,3 tonnes
Propulsion
Boilers 12 Wagner high-pressure (55 Kg/cm²) in 6 compartments 12 Wagner high-pressure (55 Kg/cm²) in 6 compartments
Temperature 475º C 475º C
Turbines 3 Blohm & Voss geared turbines 3 Brown-Boveri geared turbines
Construction shaft output, maximum unforced 111.000 shp 111.000 shp
Construction speed, maximum unforced 31,5 knots 31,5 knots
Machinery output designed 138.000 shp 138.000 shp
Shaft revolutions 250/min 250/min
Speed 28 knots 29 knots
Machinery output maximum 150.170 shp 163.026 shp
Shaft revolutions 278/min 278/min
Speed 30,1 knots 30,8 knots
Range 8.525 nm at 19 knots 8.870 nm at 19 knots
6.640 nm at 24 knots 6.963 nm at 24 knots
4.500 nm at 28 knots 4.728 nm at 28 knots
Bunkers designed 3.200 m3 3.200 m3
maximum 7.400 m3 7.780 m3
Propulsion gear (all mounted aft) Shafts 3 3
Propellers 3 (three bladed, diameter 4,7 m) 3 (three bladed, diameter 4,7 m)
Rudders 2 (paired) 2 (paired)
Armour
Belt 320 mm (12,59") (main)
145 mm (10,35") (above)
170 mm (6,67") (below) 315 mm (12,39") (main)
Deck 50 mm (1,96") upper deck. 80 mm (3,14") - 120 mm (4,72") armor deck 50 mm (1,96") upper deck. 80 mm (3,14") - 120 mm (4,72") armor deck
Forward transverse bulkhead 220 mm (8,7") 220 mm (8,7")
Turrets 360 mm (14,1") faces. 203 mm (8") - 130 mm (5") sides and roof 360 mm (14,1") faces. 203 mm (8") - 130 mm (5") sides and roof
Barbettes 342 mm (13,5") sides 342 mm (13,5") sides
Conning tower 360 mm (14,1") sides 360 mm (14,1") sides
Armour thickness (deck) max. 110 mm approx. 110 mm approx.
(side) max. 380 mm approx. 380 mm approx.
Armament
Main armament 8 x 380 mm (14,96") 8 x 380 mm (14,96")
Secondary armament 12 x 150 mm (5,9") 12 x 150 mm (5,9")
Heavy flak 14 x 105 mm (4,1") 14 x 105 mm (4,1")
Light flak 16 x 37 mm (1,46") 16 x 37 mm (1,46")
Flak - Machine Gun 12 x 20 mm/L65 (0,79") MG C/30
8 x 20 mm/L65 (0,79") MG C/38
(April 1941) 12 x 20 mm/L65 (0,79") MG C/30
78 x 20 mm/L65 (0,79") MG C/38
(July 1944)
Torpedo battery None Two quadruple sets each of 533 mm (21") torpedo tubes. Originated from a destroyer. Installed from autumn 1941
Aircraft
Catapult 1 double catapult, amidship 1 double catapult, amidship
Aircraft 4 x Arado Ar196A-3 4 x Arado Ar196A-3
Fire Direction
10,5 m Rangefinder 4 (1940)
5 (1941) 5
7 m Rangefinder 1 1
6,5 m Rangefinder 2 2
4 m Rangefinder 4 4
3,7 cm flak Rangefinder on gun Rangefinder on gun
2 cm flak Rangefinder on gun Rangefinder on gun
Radar Equipment
FuMO 23 3 3
FuMO 212/213 (Würzburg) 0 1 (from spring/summer 1944)
FuMO 27 0 1 (additional installation)
TIMOR 0 1 (additional installation until spring/summer 1944 when replaced by FuMB 4 SAMOS)
FuMB 4 SAMOS 0 1 (replaced TIMOR in spring/summer 1944)
FuMO 26 0 1 (replaced two FuMO 23 and FumMO 27 in spring/summer 1944)
FuMO 30 Hohentwiel 0 1 (from spring/summer 1944)
Equipment
Searchlights, triaxially stabilised and directed centrally
(those positioned on Tirpitz's funnel platform later replaced by flak) 7 7
Cranes 2 large and 2 small 2 large and 2 small
Ship's boats 3 barges, 4 picket boats, 1 launch, 2 cutters, 2 dinghies, 2 yawls (Tirpitz later probably fewer)
Anchors 3 bow, 1 stern 3 bow, 1 stern
Complement
Ship's company 103 officers, 1.962 + 27 men (1941) 108 officers, 2.500 men (1943)
FONTE : Jhon Asmussem
Bem chega de conversa e vamos as fotos da bagaça
A BOX ART DA CAIXA:
A CAMUFLAGEM ESCOLHIDA:
CASCO E DECK:
NESTA MONTAGEM FAREI ALGUNS SCRATCHS DE COMPLEMENTO, O DECK RECEBERA FOLHAS DE MADEIRA QUE JÁ MANDEI CORTAR A LASER POIS AQUI EM TERRAS TUPINIQUINS NÃO SE ACHA PARA COMPRAR
PEÇAS JÁ MONTADAS QUE COMPÕEM A TORRE PRINCIPAL(JÁ COM ALGUNS SCRATCHZINHOS )
AQUI OS NAVAIS AUXILIARES E BOTES COM SCRATCHS:
FORÇA BÉLICA: SCRATCH NOS CANOS:
ESTES CANOS FORAM FEITOS COM TUBOS DE DIVERSAS BITOLAS.
AQUI TUDO ENCAIXADO PARA ANALISE DE ENCAIXES E POSSÃVEIS CORREÇÕES:
Bem a montagem está neste pé até agora,estou aguardando a melhora do tempo para iniciar a pintura.
Abrçs,
Torrezani
General Details
Displacement
Measurement
(at 52.890 tonnes)
Propulsion
Armour
Armament
(July 1944)
Aircraft
Fire Direction
5 (1941) 5
7 m Rangefinder 1 1
4 m Rangefinder 4 4
Radar Equipment
FuMO 23 3 3
Equipment
Complement
A BOX ART DA CAIXA:
CASCO E DECK:
Abrçs,
Torrezani
Editado pela última vez por torrezani21 em 22 Set 2016, 23:20, em um total de 3 vezes.
F-105 G WILD WEASEL
viewtopic.php?f=19&t=11580
EH 101 MERLIN
viewtopic.php?f=19&t=11446
SPIT FIRE
viewtopic.php?f=19&t=11417
EH 101 MERLIN
SPIT FIRE
- Curtiram: 70 vezes
Re: TIRPITZ COURAÇADO 1944 TAMIYA 1/350
Fala Torrezani!
Sou fã desse navio!
os scratches ficaram ótimos. Fez os canhões com aquele kit de tubos de latão?
Sou fã desse navio!
- torrezani21
Valew Rafael,sim eu tenho uns kits da Trumpeter desses tubos,são muito bons para fazer este trabalho ,além do naval da pra uma serie de coisas.Rafael Guerra escreveu:Fala Torrezani!
Sou fã desse navio!
Abrçs,
Torrezani
F-105 G WILD WEASEL
EH 101 MERLIN
SPIT FIRE
EH 101 MERLIN
SPIT FIRE
- torrezani21
bem dando sequência a montagem foi a vez das pinturas iniciais,a camuflagem ainda está na metade,ira subir para as torres e canhões.
Segue as fotos da bagaça.
Chegaram os assoalhos que encomendei para corte a laser,mas antes vou finalizar as camuflagens nas torres.
abçs,
Torrezaani
abçs,
Torrezaani
F-105 G WILD WEASEL
EH 101 MERLIN
SPIT FIRE
EH 101 MERLIN
SPIT FIRE
- Diego Natanael
- Nome: Diego Natanael R
Re: TIRPITZ COURAÇADO 1944 TAMIYA 1/350 Atualiz. 01
Muito bacana Torrezani ! Tens uma bela máquina de guerra em mãos....
Estarei acompanhando com certeza este belo trabalho!
viewtopic.php?f=127&t=9056
viewtopic.php?f=198&t=9798
- torrezani21
Valew Diego muito obrigado pela sua visita.Diego Natanael escreveu:Muito bacana Torrezani ! Tens uma bela máquina de guerra em mãos....
F-105 G WILD WEASEL
EH 101 MERLIN
SPIT FIRE
EH 101 MERLIN
SPIT FIRE
- torrezani21
Re: TIRPITZ COURAÇADO 1944 TAMIYA 1/350 Atualiz. 02
Boa pessoal segue mais um pedaço desta montagem.
Nesta parte fiz as colagens dos assoalhos e pintura dos auxiliares navais (lanchas e botes )
Segue as fotos.
Até o momento está assim,em breve mais atualizações
Abçs,
Torrezani
Segue as fotos.
Abçs,
Torrezani
F-105 G WILD WEASEL
EH 101 MERLIN
SPIT FIRE
EH 101 MERLIN
SPIT FIRE
- Diego Natanael
Tá lindo. Vai colocar a suástica no deck?
Enviado de meu MotoG3 usando Tapatalk
- torrezani21
Valew Diego pela visita , em relação a sua pergunta, sim irei colocar a suástica na proa ,só que da forma correta ,pois muitos pitam e o correto é colocar em formato de bandeira amarrada ao deck ,ao contrário do Bismarck e Graf Spee que eram pintados,os alemães modificavam muito as camuflagens de suas embarcações e tiveram a sacada de que esta seria uma forma de além de mudar a camo quando viesse um aéreo poderiam tirar rapidamente a suástica da embarcação para confundir os pilotos das aeronaves.
Grande abraço,
Torrezani
Grande abraço,
Torrezani
F-105 G WILD WEASEL
EH 101 MERLIN
SPIT FIRE
EH 101 MERLIN
SPIT FIRE
- Emerson-Antonio
- Nome: Emerson Pereira
Incrivel os detalhes e os scratch de arame.
Enviado desde mi LG-D855 mediante Tapatalk
