[Concluído] TRU02233 - TBF-1C AVANGER - Trumpeter 1/32
- Gabrielhn
- Nome: Gabriel Hipolito
Re: TRU02233 - TBF-1C AVANGER - Trumpeter 1/32
Opa.
Não li todo o tópico todo, não vi se foi mencionado em alguma parte, mas qual o comprimento dele?
Valeu,
Até mais.
Valeu,
Até mais.
- pedro neto
- Registrado em: 26 Mai 2013, 16:23
- Nome: Pedro Gomes da Silva Neto
General characteristics
Crew: 3
Length: 40 ft 11.5 in (12.48 m)
Wingspan: 54 ft 2 in[34] (16.51 m)
Height: 15 ft 5 in (4.70 m)
Wing area: 490.02 ft² (45.52 m²)
Empty weight: 10,545 lb (4,783 kg)
Loaded weight: 17,893 lb (8,115 kg)
Powerplant: 1 × Wright R-2600-20 Twin Cyclone radial engine, 1,900 hp (1,420 kW)
Performance
Maximum speed: 275 mph[35] (442 km/h)
Range: 1,000 mi (1,610 km)
Service ceiling: 30,100 ft (9,170 m)
Rate of climb: 2,060 ft/min (10.5 m/s)
Wing loading: 36.5 lbf/ft² (178 kg/m²)
Power/mass: 0.11 hp/lb (0.17 kW/kg)
Armament
Guns:
1 × 0.30 in (7.62 mm) nose-mounted M1919 Browning machine gun (on early models) or 2 × 0.50 in (12.7 mm) wing-mounted M2 Browning machine guns
1 × 0.50 in (12.7 mm) dorsal-mounted M2 Browning machine gun
1 × 0.30 in (7.62 mm) ventral-mounted M1919 Browning machine gun
Rockets:
up to eight 3.5-Inch Forward Firing Aircraft Rockets, 5-Inch Forward Firing Aircraft Rockets or High Velocity Aerial Rockets
Bombs:
Up to 2,000 lb (907 kg) of bombs or
1 × 2,000 lb (907 kg) Mark 13 torpedo
Crew: 3
Performance
Armament
Guns:
Rockets:
Bombs:
Tem coisas que só o Pedrão faz por você!
- Gabrielhn
Show, mas quis dizer do model, hehehepedro neto escreveu:General characteristics
Crew: 3
Performance
Armament
Guns:
Rockets:
Bombs:
- pedro neto
ops....kkkkkk
- felipecadena
- Nome: Felipe Cadena
Re: RE: Re: TRU02233 - TBF-1C AVANGER - Trumpeter 1/32
Ele e vermelho vinho alemão.pedro neto escreveu:legal esse primer da valejo.... rust?
Não coloquei não mais ficará aproximadamente 38x52 cmGabrielhn escreveu:Opa.
Valeu,
Até mais.
Crew: 3
Performance
Armament
Guns:
Rockets:
Bombs:
Gabrielhn escreveu:Show, mas quis dizer do model, hehehepedro neto escreveu:General characteristics
Crew: 3
Performance
Armament
Guns:
Rockets:
Bombs:
Ops ..... Hahahahahapedro neto escreveu:ops....kkkkkk
- felipecadena
Seguindo com a pintura dei início na marmorização.
- felipecadena
Pré shading finalizado e marmorização. Agora só pintar
- felipecadena
Valeu PachecoPacheco escreveu:Muito bacana.
- Galttar
- Nome: Artur Barbosa
Que tintas são essas com o seu logo?felipecadena escreveu:Pré shading finalizado e marmorização. Agora só pintar
Instagram: artur.galttar
YouTube: galttar
Finalizados:
HV-22A Osprey - ESCI - 1/72
UH-1C Huey Hog - Revell 1/48
Lista de Kits: ScaleMates
